I've totally lost my set up CD for my Canon D1250U2F Scanner. I was wondering if there was a place I can go to download it. Canon's support is no help, they only have the drivers and not the Utility Set up. Thank You for your time.
When I click the copy button on toolbox window the window closes. Clicking on all other boxes will...
(More)
When I click the copy button on toolbox window the window closes. Clicking on all other boxes will open their respective dialog box, but for the copy button the toolbox window just closes. I have uninstalled the entire scanner program and reinstalled, and uninstalled the toolbox and reinstalled, nothing works. Canoscan D125OU2F
Hi, our canon d1250u2 makes a high pitched noise when connected to the mains. It doesn't light up...
(More)
Hi, our canon d1250u2 makes a high pitched noise when connected to the mains. It doesn't light up and the PC doesn't recognise it? Before it stopped all together it was scanning as a pure black image, any suggestions?
My computer sees the scanner but I can't get the Scangear toolbox to work, I can scan to a publisher...
(More)
My computer sees the scanner but I can't get the Scangear toolbox to work, I can scan to a publisher file without problem. I am running XP on a 64bit computer. It says "Unable to select Twain source"
Scanner will select 'Film' option but then when I press scan gives error message that original not...
(More)
Scanner will select 'Film' option but then when I press scan gives error message that original not set properly or lamp not warmed up (even after half an hour on). Scannner then closes
Preview screen remains black cannot see image to adjust, although when scan is used image is scanned...
(More)
Preview screen remains black cannot see image to adjust, although when scan is used image is scanned ok
