Question about Dell Axim X51v Pocket PC
Dell Axim x51v display problem
My x51v display (LCD) is not working properly. Sometimes the top and bottom "bands" on the screen will not display properly. Other times the Drop down menu's don't display properly (unreadable). When I hard-reset the Dell graphic looks fine. But when it boots into WM5 I then have the graphics issue. This problem started all of a sudden after I changed the battery. Going back to the original battery didn't help. Also, none of the icons display properly (consistently). Can the entire OS be reloaded?
  • 0Catalyst0 Dec 30, 2008
    I have the exact same issue, as well as the front buttons not working except power and calender. It also says randomly that the battery latch was opened and its not. Not to long ago i put it back into the box because the touch screen quit and without the front buttons there was no way for me to interact with the device. I took it out today to discover that the touch screen is now working once more. this is my 4th replacement and the warranty is out now so im stuck with it. it seems that quality wasn't a priority for dell in this case, the worse shock any of them went through was the stoping at the end of my pocket. if they cant handle that i have ben riped off but seeing im stuck with it im going to half to take it one problim at a time. so any help would be much apprecaited.
SOURCE: dell axim 51v
I have the same problem. Its from an over sensitive switch. You arent actually opening the battery case you are pressing against it. This triggers the switch and makes it think you are taking the battery latch off. I haven't actually tried it but you could open up the Axim and cut the cable going to that sensor/switch?
Posted on Mar 11, 2008
  • 3 Answers
SOURCE: reset button won't work
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Posted on Apr 06, 2009
  • 17 Answers
SOURCE: how to install windows mobile 6.5 on a dell axim
I'm starting the same thing myself. It looks complicated unless you do a lot of Pocket PC stuff. I've done a fair amount myself, but this is my 1st foray into the "cooked" ROM arena. Looks like Lenny's L14 is the best, it's wm6.5 for some technical reason I believe. has been an outstanding source of info for many of my undertakings & issues! AximSite Forum 1
Forum 2 has been rolled into MobilitySite and it was great too. Below are a few of the links I've been referring to.
Be AAAAAABSOLUTELY sure to backup your data!!! SPB backup has been great for our brood - it even lets you go cross device which you'll esentially be doing. Backup to a BLANK formatted SD card! The B/U is self extracting and very configurable both in and out. I lost a serious amount of stuff (life) when I restored & ActiveStink tried to sync my card with an empty database! My fault I'm sure, but still reeeeealy hurts. :(
Scared?? You should be, that shows you've got some common sense. Aside from data loss, you can brick your x51v if something goes wrong. That costs a bit to fix, I guess they have to physically go in and re-flash the ROM. Never tried it personally... ;)
As my good friend Miguel used to say, "GOO' LUCK FELLA!"
Cooking Downloads
Downloads (use Mega, it's faster than Rapid for me)
GOOGLE search
Posted on Oct 18, 2009
  • 17 Answers
SOURCE: Why do I get a battery latch open warning Axim x51v
There is a sensor on the latch that detects when it has opened. Over time, the sensor wears down. You can put a dab of glue on it (so that the button presses down even further) or fold a tiny piece of paper onto it. You can find the sensor right above where the latch is, after you've opened the back cover.
Posted on Nov 21, 2009
  • 561 Answers
SOURCE: set password on my dell axim X51v pocket pc and forgot it
Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device.
Hard Reset -
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
Posted on Jan 15, 2010
Dell axim x51v pda
You need to do a hardreset on the pda to get the password removed.
Jul 24, 2008 | Dell GG057 for Axim X51, X51v
My phone dell axim x51v,the touch screen is not working also the keypad.
might have slipped from your hand, take that to a service station for upgradation might ribbon to be replaced
Jun 24, 2011 | Dell Axim X51v Pocket PC
I have a dell axim x51v stuck on dell logo
First check to see if any of the buttons are stuck. If that doesn't help, try a few simple things with the digitizer, the thing you write on. It could be stuck.If there are any gouges, dents, deep scratches or cracks, that could do it, it's toast - but self repairable if you dare. -However- 2 things to try first just for giggles though if there are no cracks: #1. Use your joystick & enter button to navigate through the Start Menu to Settings>>System>>Screen>> Align Screen and align the screen. Worth a try. #2. There might be some crud stuck between the edge of the digitizer and the edge of the case. That can give you phantom key presses. Take a piece of stiff paper or thin plastic and run it *gently* around under the edge where the case covers the screen to scoop out any stuff that may have settled there. Those blister packs that cut you up when you try to open them works well, credit card is too thick for my taste. #3. If it's been around water, there's a very slight chance that putting it on top of the clothes dryer for a few loads will dry it out.Beyond that, needs technical help.
Mar 16, 2010 | Dell Axim X51v Pocket PC
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
Dell Axim x50v, x51v
Dec 15, 2009 | Dell Axim X50 Pocket PC
Forgot my password on a Dell Axim X51v Pocket PC
do a hard reset to your phone so as to work's how;
Oct 06, 2009 | Dell Axim X51v Pocket PC
Dell axim 51v
Mar 06, 2008 | Dell Axim X51v Pocket PC
Dell axim x51v and dell d810 conflict
Thats an easy one, simply uninstall your active sync reboot with axim of cradle then install newest version here :
Aug 05, 2007 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC Logo
266 people viewed this question
Alun Cox
