Question about GE 27831 Cordless Phone
Base unit light blinking GE 27831
When I hang up the base unit handset the LED on the base starts blinking and continues forever.
When I remove the handset from the base - but not use it - the LED continues to blink.
When I use the handset the LED on the base turns solid indicating the phone is in use and/or needs charging.
The second phone with this system in the other room operates normally.
I've disconnected the power to the base unit, restored power, resync'd the second unit, and still have the same blinking problem on the main receiver base unit.
Am unable to remove the battery from the handset as I will lose the stored numbers and I can no longer see well enough to put them back in.
This phone system is 7 months old and I like it, except for the blinking LED (which started a few weeks back and is bugging me).
Thanks in advance for any help / thoughts / etc.
  • Emmas gram Sep 19, 2008
    I know about the voicemail waiting - but I have listened to and deleted all my voicemails and it still blinks. It started with the hurricane Ike storm winds when our power was out. I have read the book, unplugged, tried to delete voicemails again - nothing works...Help if you can. My phone is model 25931 Series 5.8 GHz
I had the same problem. Once I read the owners manual I found the charge light blinks to indicate that you have voicemail waiting to be retrieved via telecom provider. Much to my surprise I have a voicemail account I never requested.
Another mystery solved - I now know why I missed so many messages.
Posted on Mar 09, 2008
How do you reset the base unit on a uniden 1558-5 without the handsets
Disconnect power.
Press and hold find handset key or "Find" or Find HD
Connect power
Continue to hold find handset until the charge led blinks
Aug 13, 2015 | Uniden Lands Phones
Power outage need to reset - blinks "CL"
remove the power adapter and remove the battery from the handset. Now replace the battery and power the base unit , place the handset on the base and select intercom or search remote.
The base unit must automatically set the frequency to mesh with the handset and handshake to connect.
Sep 19, 2011 | GE 25932 Cordless Phone
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
The charge light is not on when charging the phone
i have the same problem, but the handset dont charge. u have to change a zenner diode, inside of the base.
Nov 08, 2008 | GE 27831 Cordless Phone
The unit light doesnt light up, is it broken
you have to change a zenner diode inside of the base unit.
Jun 19, 2008 | GE 27831 Cordless Phone
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
My second handset is disfunctional
you have to put the second handset on the primary base for about 20 seconds for it to accept it, then you will get a tone and everything should work fine from there.
Nov 08, 2007 | GE 27831 Cordless Phone
Ge cordless model 27831 issues
you have to place the handset 2 in on the main base by 'round 20 seconds so it will be registered by the system
Apr 28, 2007 | GE 27831GE2 Phone
Blinking lights
The blinking cordless handset seems to be your main issue. IT should not continue to blink after a start up. I think if you replace the handset and sync it to your base station, your problem will be resolved. The T7406 phones are not the most rugged handsets. IF this unit was dropped, a lo of your symptoms make sense.
Jan 15, 2007 | NorStar T7406 Cordless Phone
GE 27831 Cordless Phone Logo
633 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
