Question about Motorola Mobility MPx Pocket PC
Flex cable for lcd broken
Dear sir ,
I am currently in brunei , need some assistance to where to purchase motorola mpx flex cable for display lcd or entire set of lcd with flex cable.
Thanks for your most valued assistance.\
Raymond Sy
Lcd flex cable
flex cables are largely available and easy to replace. post your current location and i will assist you locate nearest store and give you instructions on how to replace the same.
thanks for using fixya!
Apr 22, 2012 | Motorola Mobility KRZR K1m Cellular Phone
Touchscreen stopped working
HERE'S A LINK TO REPLACEMENT SCREEN... http://www.cellulardr.com/motorola-cliq-xt-mb501-faceplate-with-touch-screen-digitizer-and-lower-navigation-keypad-assembly-with-flex-cable-tmobile-quench-front-housing-frame-with-touchscreen-lens-glass.html?cat=248
THIS IS THE SITE: THERE ARE TWO DIFFERENT SSCREENS, ONE WITH THE WHOLE FRONT PANEL FOR $100.00 AND ANOTHER WITH JUST THE SCREEN PART FOR $89.00 YOU CAN CALL: Call 818-553-2700 OR HERE'S THE LINK: http://www.cellulardr.com/motorola-mb501-cliq-xt-main-lcd-display-screen-with-flex-cable-tmobile-quench-main-lcd-display-module-with-flex-cable.html
Dec 17, 2010 | Motorola Mobility CLIQ Cell Phone
Model NO. - MOTOROLA - W270 Defect - Display unit got failed How many days required to provide new Display unit and what will be cost ?
The LCD Flex Ribbon Cable is the usual culprit and costs about $5. The screen itself can be purchased for about $10. The parts typically come from China, so it will take 1-2 weeks for delivery.
Nov 29, 2010 | Motorola Lands Phones
My motorola razor v3 has a white screen?
Hi, White screen on motorola razor phones can be caused by either the LCD or the flex of the screen.
First, you will need to check for the flex by replacing the flex of the phone. the flex controls the display of the phone and the keys on the keypads of the phone.
The LCD also can cause a white screen display. After replacing the flex and if it's still has white display,you will need to replace the screen.
Have a nice day.
Sep 16, 2010 | Motorola Mobility RAZR V3
WHEN MY PHONE RINGS IT'S NOT SHOWING ON THE OUTSIDE OF THE PHONE WHO IT IS THATS CALLING..IT'S NOTHING ON THE SCREEN...HELPPP
Sounds like either a defective LCD, or a defective flex cable. The flex cable is pretty common to fail, especially if the chrome hinge pin has broken. The parts can be purchased on ebay or other sites, but without seeing the phone, its hard to determine which. I recommend taking it to your local phone repair shop for repair.
Dec 14, 2009 | Motorola Mobility RAZR V3
Motorla MPX220 Screen turning Red
where you got the flex cable from.....
Nov 03, 2008 | Motorola Mobility MPx220
My MotoROKR E6 display is not working. i have checked mobile with local repair center. They said display problem need to replace. Please assist how much does a display cost?
This may not be the problem with your phone, but I had the display go out on another motorola (razr) and it was the flex cable that goes from the main board to the screen. Since the ROKR doesn't have a flex cable it is less likely that is your problem but it is worth checking the cable to the LCD anyway. I know that with the RAZR, the cable is fairly loosely held in place and would be easy to knock loose if the phone was dropped.
If that is not the problem, you should be able to get a display on ebay for a lot cheaper than from Motorola. here is a current auction for an LCD: http://cgi.ebay.com/For-Motorola-Z6-Rokr-Original-LCD-Display-Screen-Tools_W0QQitemZ300242976439QQihZ020QQcategoryZ20336QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
if you can't find the LCD by itself I would recommend looking for a broken phone on ebay to swap screens with.
Jul 18, 2008 | Cell Phones
Screen will not display
I have had the ribbon cable go defective in flip phones. In some phones that I had backlight went defective. These were not all Motorola.
The fix in my phones was to change the screen and ribbon cable. If the phone was out of warranty, I retired it and bought a new one. The cost of repair was too high in relation to the repair.
Jerry G.
Apr 29, 2008 | Motorola Mobility RAZR V3
Display problem
you need to have the phone lcd replaced,take it to a mobile service center and have them replace it for you.
Feb 08, 2008 | Motorola Mobility MPx220
My MPX220 internal LCD broke
I would personally suggest going to ebay. They carry many replacement parts for cell phones such as the Flex cable that you need, and are quite inexpensive as well. I guess figuring out how to install it is the tricky part. Good Luck!!!!
Feb 11, 2007 | Motorola Mobility MPx220
Motorola Mobility MPx Pocket PC Logo
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
