Question about Mitsubishi VS-50803 50" Rear Projection Television
Turns on and off by itself unless I'm using the menu
When I plug it in it turns on by itself and then will start to turn on/off by itself unless I'm in the main menu. Can I fix this myself? Any advive would be greatly appreciated.
This is just a suggestion because I had a similar problem with a Zenith TV many years ago. It was something in the tuner/remote sensor circuit that made the TV randomly turn on or off. You may have to have it repaired by a technician, but here is something to try: Put tape over the remote sensor eye on the front of the TV. This is to make sure some stray light is not turning off the TV.
Posted on Dec 23, 2008
Dtv on menu is greyed out
" Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' until option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal."
Aug 26, 2018 | Televison & Video
I have a TV Vizio Model N E420i-B0 that after a while turn itself of. Some times comes back on by itself, but most of the time you have to unplug it, wait for a while and plug it before turn on again
A lot of vizios do this, try a factory reset and see if that works. go to menu on remote, then click on system,then click on reset and admin, follow info to reset. God-Bless! make sure the timers are turned off first.
Nov 15, 2017 | Vizio Televison & Video
My wm2455h turns on by itself and after some time, it turns off. What is causing this>
It seems that the Main Control Board of your washing machine is playing up. The fact that when you unplug the machine from the mains, the main control board resets itself and you are able to start the machine points in this direction.
Nov 17, 2014 | LG WM2455 Front Load Washer
How to reset samsung LA32R71BD
Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new.
May 20, 2014 | Televison & Video
TV has a mind of it's own. I turn it off & it turns itself back on. It pulls up the input menu without me hitting the input button. Then it switches between the input options without me hitting...
U have some skills like take things aparts and putting it back together again?Yes?The tv Tuner signal board have problems,might even be the CPU itself have some kind of shorts.The Tuner signal board,that the board,where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Oct 28, 2010 | LG 47LG50 47 in. LCD HDTV
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
My laptop wont boot up and just resets itself help!!!!!!!!!!!!!
Try this turn off.Restart hold F8 Key. A menu will ask How to start, Chose Safe Mode.
If unit starts you will have limited use to find out what is causing the issue.Go to start click it then chose system restore and chose a date that unit started(you will lose some programs that were installed after that date but not data in files.If you don't want to use system restore you can try to 1.remove a new program that you installed and is causing the problem.2 disconect any new hardware.3.click start and click control panel,system,device manager,hardware and look for anything yellow, expand if you can to see any yellow ! marks thats your problem.Remove uninstall unless you need it.Restart,I have used System Restore many times it will fix your PC.Good Luck
Sep 04, 2009 | Computers & Internet
I Acer Aspire 5310 cant charge battery unless the
you hav to change the chager you are using
Aug 14, 2009 | Acer Computers & Internet
JVC model LT-37xm57 will not stay on
I believe it is an overheating problem...
Short term fix...place a small fan behind your TV on bottom right hand corner and your TV will not shut down
Mar 24, 2009 | Televison & Video
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
