You have to completly thaw out the the freezer and dry off all moisture with paper towels then turn back on be sure to wipe the rubber seals down so no moisture is pulled out of the air between the seals of the door and cabnet.
Comments:
Oct 17, 2009
- You have to completly thaw out the the freezer and dry off all moisture with paper towels then turn back on be sure to wipe the rubber seals down so no moisture is pulled out of the air between the seals of the door and cabnet.
Oct 17, 2009
- Yes you have to dry it out or the mositure will return. after each door opening it will draw more moisture out of the air each time we open it.
Was this helpful?
Yes
No
Popular Solutions for GE Side by Side Refrigerator
the part of the waterline that feeds water into the ice making machine has fallen off. How is best...
(More)
the part of the waterline that feeds water into the ice making machine has fallen off. How is best way to get it reattached?
one year old GE side by side freezer works erratic.seems to defrost and then freeze then defrost...
(More)
one year old GE side by side freezer works erratic.seems to defrost and then freeze then defrost again.
We have a GE side by side fridge. The freezer seems fine, but some of the ice cubes may have melted...
(More)
We have a GE side by side fridge. The freezer seems fine, but some of the ice cubes may have melted as there was a ice block in the bottom of the ice cube maker. The fridge is not cooling. This happened overnight- from working to non-working.
