Question about Garmin nuvi 260W GPS Receiver
  • 8 more comments
  • juhwhit Feb 13, 2008
    My Garmin 610 also froze while in use today. Really bad as working carer and missed last call. I have no idea how to resolve the problem...
  • Anonymous Feb 16, 2008
    my nextar navigator is frozen it will not load up tried repowering it but still nothing
  • mirann Mar 16, 2008
    downloaded new infomation and now the screen has totally frozen.what do I do now?
  • David Peebles Mar 29, 2008
    When the system was being charged by an external charger via the USB socket, the Garmin screen displays the GARMIN title and a symbol depicting connection to PC. However, I can't get the system to switch off or respond in any way?
    Help please!
    Many thanks
    David P
  • amqai Mar 30, 2008
    I am having exactly the same trouble with navman f20 and it's doing anything at all, not even turning off. Please help me out.
    Thanks in advance.
  • 1234shellie Apr 16, 2008
    i got it 3 hours ago and it just froze i can't do anything
  • Anonymous May 23, 2008
    I bought Edge 305. I configured all initial set ups and customize what I needed to have. wanted to go for a ride next morning. Switched the unit on and it just froze. nothing helps. It reacts to nothing and my PC is not able to detect it either...
  • shootn2233 Dec 13, 2008
    frozen screen
  • kdoveston Feb 11, 2009
    tomtom froze now it wont turn on
  • chezsoni8 May 11, 2010
    How do you reset a garmin 260? my touchscreen doesn't work.
By David707,
Since posting ma last re: Screen Freezing on external charge; I did manage to get the system back to some normality by pressing the Reset button located underneath the GPS Antenna flap. However this is likely to delete personally stored data on the system.
I should also state that the same problem occurs when I connect the 610 t my PC via the USB connection (another way to externally charge the battery).
A more satisfactory answer required though.
Posted on Mar 29, 2008
I have a Mondeo titanium 2010 with a Blaupunkt sat Nav SD card version. the screen suddenly went blank, not only leaving me with no sat nav but also no control over heater, air con, no radio volume. the...
Search finds little on your problem which is odd. I think you need a visit to the Dealership. when was it last serviced? Book it in for service and and ask them to look at that at the same time. You will get a better price and value for money.
Mondeo titanium 2010 Blaupunkt sat Nav SD card version the screen suddenly...
Nov 19, 2017 | Blaupunkt GPS
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
I was using my Garmin sat nav when the screen froze. It would not even switch off let along allow me to do antything on the screen. It is 18 mths old.
Allow the unit to power itself off by draining the battery.
Once that is done, connect the unit to a vehicle power supply or an AC power supply to charge it back up.
Try running the Garmin WebUpdater.
Download and Install WebUpdater.
Aug 31, 2011 | DURAGADGET Garmin Nuvi 205 GPS Satnav...
Garmin 1200 suddenly stopped loading up....
I am haveing the same problem
Can not seem to find any reason?
Mar 31, 2010 | Garmin nuvi 1200 Car GPS Receiver
Sat nav froze
i turn on my gps on itz froze aint nothing comming up after
Jul 29, 2009 | GPS
Buttons and screen not responding on via michelin x-950t sat nav
stick a pin in the reset hole in the back.that should fix the problem.
Mar 01, 2009 | SNK ViaMichelin Handheld GPS Receiver
BMW X5 - 2005
Hi kuldipdhanja this sounds like it could be an internal fault with the video module or the sat nav drive, you could try discontecting the battery negative lead for 15 minutes to reset the control units, you will have to remove the spare wheel and unfasten the air compressor bracket to get to the battery, this fix may only be temporary but it is alot cheaper than replacing parts. regards mark.
Jan 26, 2009 | 2005 BMW X5
Can you put factory sat nav in an X5 when it does not already have it in
Hello There
Yes it is possible to install the factory sat nav in you X5, but apart from the head unit you will also need:
  1. new wiring loom
  2. dvd navigation unit installed at the back
  3. TMC radio unit again at the back
  4. bluetooth unit
All the interior needs to come out i.e seats, floor carpets, door trims.
If you feel brave enough then there are BMW forums which gives you very detailed information on how to to it, but don't expect to get it done in a day or even two, a week is probably realistic time. It took me 2 weeks to do my first 3 series.
Hope this helps. Please don't forget to rate me.
Many Thanks
Jul 12, 2008 | 2005 BMW X5
Navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Jun 10, 2008 | Navman F20 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
426 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
