Question about Kyocera CS-2550 Black and White Copier
Scanner will not connect to PC
I have a Kyocera CS-2550 and when I try to scan I get error message unable to connect to PC; check PC. Everything is connected but I do have a inconsistent red flashing light under the green light on the "ST" spot.
  • 2 more comments
  • steel123 Jul 02, 2008
    I am able to scan to my pc which has an ip of 10.0.0.92, but I can't configure any other pc.
    Does each computer have to have file utility running? I already installed it on another & added a folder in his list, but it still won't scan.
    On the folder # in file utility - does it have to match the # for the destination pc? If so, I already did this too.
    This is the confusing part:
    The destination List (PC) asks for:
    • Name - User2
    • Registration Number - 003
    • PC address - 10.0.0.35
    • Save number - 001
    File Utility asks for:
    • Folder # - 001 - does this need to match "Save #" or "Registration #"?
    • Folder address - "C:\Scans"
    Any help would be appreciated.
    G
  • sunjayng Aug 20, 2008
    i have set up a gestetner colour copier on the network that is able to print and scan from the pc. But whenever i try to scan to folder from the machine it will give error message "not able to connect to pc". kindly help me out.
    my e-mail address is sunjayng@yahoo.com
  • mjevans1 Dec 02, 2008
    I just received the CS 2550 and I set it up on my network and it did not come with any software. What software do I use to connect to this printer/scanner? I have been searching the web for it and can't seem to find it. Please any info is appreciated.
  • Anonymous Mar 25, 2014
    cannot connect to my Samsung scanner through my network
    Sniper:
  • 54 Answers
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Posted on Jan 01, 2008
How to connect from pc to HP Laserjet3052 scanner?in this problem is scanner connot connect to PC and also scanning error?
Posted on Jul 15, 2009
Print mode error
check that the paper size is correct on your machine then turn it off and on and the device your printing from. basically reset both. if that doesnt solve it check that the driver is correct reload driver and check connections
Jun 18, 2014 | Kyocera CS-2550 Black and White Copier
Error message: two copy to two copy
my guess is u got the cheap version without the duplex option
Apr 23, 2010 | Kyocera CS-2550 Black and White Copier
I have a kyocera cs-1650 and am trying to scan to PC. Error message: Destination PC Folder is Different-contact admin. Can you help?
scan yo pc use file scan uitility , make sure you install that program, configure it, it seems you did not configure the folder where the scan has to go, so you go this error.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Dec 29, 2009 | Kyocera Copystar CS-1820 Black and White...
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
Kyocera 2550 Scanner I'm unable to connect via browser
Check the PC that you are trying to scan to amd make sure that the Scanner File Utility is up and running. You can check this by looking for the scanner icon in the bottom right corner, if it's not there click on start, all programs, scanner user software, scanner file utility, click on Scanner Utility to bring it back up, it just might have gotten closed accidently. If none of this works go into the control panel and click on firewall amd make sure file and printer sharing is checked, if it is you may have to turn Windows Firewall off to make the Scanner work.
Aug 19, 2009 | Kyocera CS-2550 Black and White Copier
Massage keep coming print error mode
This could be something as simple as out of paper to the wrong IP address or a configuration problem. Check the printer driver for the way it is connected. LPT port, USB or Ethernet.
Jul 07, 2009 | Kyocera CS-2550 Black and White Copier
I'm try to print a PDF file by Kyocera CS-2550 but after i press print button it's not print and in the kyocera screen I see Print Mode Error
change the driver from kpdl to pcl xl, this is normal problem with pdf files. you do this from ur computer driver.
Jun 16, 2009 | Copystar CS-2550 All-In-One Printer
Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
The password is 6482, this is the admin password for all copystar machines.
Thanks for using Fixya
May 20, 2009 | Copystar CS-2550 All-In-One Printer
ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Oct 30, 2008 | Kyocera Copystar CS-1820 Black and White...
Scanning problems
reload your driver that came with the printer,be sure to go to properties and select shared.Although the print and scan functions use the same network cable they have diferent IP addresses and the driver software assighs the IP for scan funtion.
Mar 03, 2008 | Kyocera CS-2550 Black and White Copier
Kyocera CS-2550 Black and White Copier Logo
4,052 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
