Question about Elo (822636-000) (Gray) 15" CRT Monitor
Touchscreen not calibrated
Cannot use ouchscreen cause the targets only work when i touch way toleft of irst one. i tried re install still same. Any ideas?
  • 82 Answers
Try to recalibrate if this doesn't work, the touchscreen glass needs to be replaced
Posted on Aug 27, 2010
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
HOW CAN DO PHONE CALIBRATION?
Over the time, the touchscreen might have to recalibrate for better touch precision. If you press 1 but it activates 2 in the To calibrate Nokia 5800 touchscreen: Click the menu key > Settings > Phone > Touch Input > Touch screen calibration. There you are prompted to tap centre of target with stylus, where the 4 circles (target) at the corner animates one by one to guide user complete the touch screen calibration process.
May 05, 2010 | Nokia 5800 XpressMusic Smartphone
Hi please help....having problems with lg viewty....touchscreen contact is out of line....i have to touch approx 1 cm below to actual target to view and cant execute ''ok'' and ''options'' at all....please...
you need to calibrate your screen... go to your settings and find your touch screen settings. there should be a place to calibrate your screen from there.
Jan 31, 2010 | LG KU990 Viewty
Touchscreen calibration in ubuntu
The touch screen on these models do not have a calibration setting. They work or they don't. If it not working properly you can try uninstalling the drivers for the touch screen, then reboot. The machine will find the touch screen and reinstall the drivers automatically. Also check for any updated drivers at Panasonic's support site. Then check the connection for the touch screen, the touch screen has a separate connection than the screen, and it may have worked loose or have a little dirt or corrosion built up. If this doesn't work, then I'm afraid that the touch screen may be wearing out, nothing you can do for this.
Sep 01, 2008 | Panasonic Toughbook 28 Notebook
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Stylus Does Not Match Up With Touch Screen. Has Been Like This For Ages. Sent It Back Once But Did'nt Make A Difference. Could You Maybe Give Us Some Money Back?.
I think your touchscreen must not be calibrated correctly. Turn on your ds without a game and go to the little tiny ds a the bottom. Then click on the yellow orangish icon and it will start calibration. Just touch the marks with the target things to calibrate it.
Jun 23, 2008 | Nintendo DS Console
Screen problem
Sometimes 3rd party apps that don't work so well with the palms can freeze them up.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=2,E=0000000000825403011,K=4996,Sxi=18,Case=Obj(26419)
You could do a hard reset and when you initially sync the palm, when it asks you for a profile choose a new one and see if this method removes your problem.
Diagnosing problems by 3rd parties link- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
More info-
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Jan 08, 2008 | HP iPAQ RX3715 Pocket PC
Can't get past the calibration page, keeps shutting off
Did you install any 3rd party apps?
Diagnosing problems by 3rd parties- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
Aug 31, 2007 | HP iPAQ RX3715 Pocket PC
Elo (822636-000) (Gray) 15" CRT Monitor Logo
333 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
shahid_ptv
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
