Question about RCA HD52W59 HDTV Projection Television
RCA HD52W59 Wavy lines
My RCA HD52W59 has wavy lines that run horizontally on the screen. Has anyone else experienced this or knowwhat the issue/resolution is.
  • RCA Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid chaRCA HD52W59 Wavy lines - 578ba6c.jpgr>578ba6c.jpg
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from
TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Mar 09, 2012
    Problem Solver:
  • 4 Answers
Yes, mine is a hd52w66 i paid $180.00 to have this fixed a week ago and it has happened again. my model does not have a convergence option from the menu so i cannot adjust mine.
Posted on Dec 30, 2007
Wavy lines 2007 philips
try repositioning the board into it's slot
Apr 25, 2014 | Philips Lj41-04218a For 50pfp5332d/37...
My samsung projection tv has blue wavy lines on top of screen, I adjusted convergence, the blue will not line up horizontally, is there a inexpensive solution?
It means one of the chips has a bad section inside it, both chips and maybe a resistor near them will have to be replaced, involves soldering as each has about 18 pins soldered in
Check with TVrepairparts.com who sells some kits for this by brand and model number
Dec 09, 2012 | Televison & Video
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Wavy horizontal lines on bottom of RCA 36in Truflat TV
The convergance or y-sus board can become faulty. The capcitors do tend to burn out. It is about a $250 + repair for this. Not all parts can be repaired, but they can be replaced. A capacitor tester and multi-meter are about the best tools for the job. If the price you get is over $250, I simply would replace it instead of repairing it..
Sep 13, 2009 | RCA TruFlat 27F520T 27" TV
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Green lines? Greenish tint to black colors on tv
ohh noooo call a good repair man...
tap on the green crt and check for liquid on the board
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
RCA F32450 32" TV wavy picture
Most RCA repairs on your chassis series require a new IHVT,
AKA flyback transformer . Inside an Integrated HVT are diodes
that can degrade and give the appearance of a bad cap....
Of course, you should check the electrolytics with an ESR
meter, just in case....
xformer part # 257805 or Asti 2078........T.
Nov 04, 2007 | RCA F32450 32" TV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
RCA HD52W59 HDTV Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
