Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
I have had my mobile dishwasher for about 3 years now. It recently was having problems draining out all the water that collects in the bottom of the machine. I hook it up to the sink and plug in the power and attempt to run a normal cycle, but when I go back after the cycle is complete there is tons and tons of water in the bottom of the machine still. I have had to manually remove the water, cup by cup in order to remove it all. I used to be able to put it on another cycle and it would drain all the water out, but now it won't even drain during the drain cycle anymore. My B/F is a licensed plumber and he did some investigating into the problem and we found that the motor still runs and kicks on at the right time, but no water comes out of the hose. Please help me fix this problem so I can go back to using to wash dishes, rather than hold the clean ones I had to hand wash.
Thanks,
Bridget
To properly drain and clear out any clogs in a dishwasher:
1.Take a wet/dry vacuum, remove the paper air filter (usually just a screw) from the inside of the vacuum body
2. Empty out the vacuum body prior to using it.
3. Then **** out all of the water from the inside basin/tub.
4. Before you turn off the vac, lift the hose high into the air and make sure all of the water is sucked into the vacuum to prevent any water still in the tube from making a mess.
5. Dump that water. This will provide you an opportunity to remove excess water before you get to work.
Next, under the sink there you will see your drain, just above your drain you will see a black or transparent tube about 1" in diameter.
6. Unscrew the tube screw.
7. Get your vacuum hose and hold it near the tube. When you take off the tube, there may be, though likely not, some excess water in the tube. **** this up if needed.
8. Put the vac hose onto the tube and make an air tight seal with your hand over the hose and tube.
9. Turn on the vacuum and such out any clogs.
10. Turn on your dish washer and let it run for a minute or two to get water back into the tub.
11. Open the door, there should be about 1-2" of water in the tub.
12. Hit the cancel button and let the water pump out of your tub, be sure to hold the vacuum hose over the tube and **** out all the water with the asistance of your dishwashers pump.
13. Repeat steps 8-12 2-3 times. You should notice water will no longer remain in the tube when you fill it up, & press the cancel button because the machine will pump everything out for you. Once you have done this and the water pumps out without a problem you have fixed your clog.
14. Reattach the tube to the drain using the tube screw.
15. Dump the water from the vacuum down the drain.
17. Clean up and put your vacuum away.
16. Put the $95 into your savings account because you likely just fixed your clog in under 45 min. from start to finish.
I hope this helps!
Posted on Aug 18, 2009
Try cleaning the filters in the basin of the dishwasher. there are two of them a larger one with larger holes and a fine mesh one in the center.
Posted on Feb 27, 2008
IT IS PROBABLY A BAD TIMER OR DRAIN SOLENOID
Posted on Jan 18, 2008
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
Dec 21, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 25, 2010 | Frigidaire Dishwashers
Sep 07, 2010 | Frigidaire Dishwashers
Nov 03, 2009 | Frigidaire Dishwashers
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Aug 26, 2008 | Dishwashers
Jul 12, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Apr 03, 2017 | Frigidaire 24 in. FDB1050REC Stainless...
3,254 people viewed this question
I'm having the same problem. Water doesn't completely drain and I have to use a spoon and cup to dip the water out and dry with paper towels. Would like to know is the problem is worth fixing. My 16-year old dishwasher was in the condo when we moved in. However, the former owner had never used it.
If I hire a repairman, what would you suggest he look for? And are there repair parts for a 18" built-in dishwasher this old.
Iluvcountrylife@aol.com
I have taken everything apart in the bottom of the machine and cleaned it all. We even went so far as to take the underneath portion off and cleaned everything in there too, that is where we discovered the motor still works.
After some more investigating on my own and some research, it looks like that we are able to purchase an under counter model and just put it into the "portable" case that the old one is in now.
Thanks for all your help everyone.
