Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony kp-46wt500 the picture on my tv looks blurry and the three colors look seperated on the picture. And also it will not focus when you press flash focus.
  • Anonymous May 27, 2008
    I suspect convergence needing a multipoint convergence adjustment however the symptom is a slightly blurry picture.
    Not blurry to the point of distraction but far less sharp than it's ever been.
  • 1,113 Answers
You have convergence issues
See this link
and this one
Posted on Dec 29, 2007
Problem with picture disorder Kp-46 WT 500
What you're describing, the closest thing I could think of is a Convergence issue. The three colors look all off like a 3d image. This is a bad convergence circuit. General T.V. repair cost is 350 dollars.
Jun 20, 2011 | Sony KP-46WT500 46" Rear Projection...
Colors seperate
Yes, this problem is fixable.
Replace convergence out chips on D board of tv to fix the color separation issue.
Jun 05, 2010 | Sony KP-46WT500 46" Rear Projection...
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites,Tv reapair to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
The tv all of a sudden went out of focus and the Flash Focus will not re-set it any idea on how i can focus without expensive service call?
It looks like you have a convergence or vertical problem. if the picture is showing kind of 3 d or warped, its convergence.
Feb 22, 2010 | Sony KP-46WT500 46" Rear Projection...
Flash Focus does not focus the TV colors are seperated
if that doesn't work it will need new convergence IC's put in as well as a resistor or two
Oct 29, 2008 | Sony KP-43T90 43" Rear Projection...
Convergence issue
You need to replace both STK392-560 convergence ICs and some of the 4.7 ohm 1/2watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions.
Jul 23, 2008 | Sony KP-46WT500 46" Rear Projection...
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony TV KP-46WT500
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from . It includes replacement coolant,step by step instructions, support, etc.
Jan 14, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
211 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
