Question about Evenflo Aura Traditions Travel System Safari Trek Stroller
Computer does not recognize drive
I have a memorex traveldrive usb 2.0. My computer has stopped recognizing it when I try to use it. What do I do?
    Problem Solver:
  • 12 Answers
Have you tried turning off your computer and rebooting it back up. Are going the the backup sorce of the computer and doing a backup.
Posted on Dec 29, 2007
Good day. I have a memorex ultratravel drive USB 2.0 160GB. Everytime I connect to any computer I get the message:The pc does not recognize the USB device code 43. Please let me know what i can do. thanks...
Code 43 is the death code - the pc simply cannot communicate with the attached device because the device is not working. This means that the Memorex is dead . Since the electronics board inside it cannot be repaired or replaced it means that yo must buy a new one.
Apr 09, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
Memorex Mini Travel Drive 8 GB USB 2.0 Flash Drive 2 drives are not recognized. Error message asks to reformat. Tried them at various computers including PC and Mac. Thanks. Yee
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Feb 18, 2011 | Memorex Mini TravelDrive - USB flash drive...
My computer does not see the Traveldrive when I plugged it in the USB port. Both my PC and laptop used to recognize it but now they don't see the Traveldrive at all.
Try one worked again if the problem remains a problem in the USB stick in the old and should be open and explore the errors that can occur within such a breach or Removing the tin solder by other
Apr 16, 2010 | Memorex (32601080) 8 GB Hard Drive
My computer has stopped recognizing my drive
Hi Take a look HERE first as it covers most common issues.
If you still have issues write back here and lets see what else we can do to get you going.
Bob
EXMOD
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Mar 08, 2010 | Memorex Ultra Traveldrive - 80GB 80 GB...
80gb ultra travel drive is not recognized by computer when the hard drive is attaced to it. the main board is just fin that plugs into the usb but when I attach the hard drive to it the computer no longer...
One thing is if the drive draws more than the alloted .5 amp from the USB it the motherboard will turn off the power. SOME of these drives require a 5 volt external power supply. Some of them rob two USB ports to get adequate power.
Jan 15, 2010 | Memorex Ultra Traveldrive - 80GB 80 GB...
Some pc's don't recognize my travel drive
I have a USB hard drive, and I have noticed that on some systems the current Draw on the USB port is too high for systems with unpowered / Low power USB ports, and therefore it doesn't work for that system,
this issue can be bypassed by using a "powered" USB hub
Mar 24, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
MY VISTA NOTEBOOK WON'T RECOGNIZE THE MEMOREX 4 TRAVELDRIVE
Lb44145 ,when you got the item did it come with the disk? And if you have the packaging does it say 'Vista Compatible' if not i would recommend you buy one which is vista compatible.
Good luck,
Ben
Feb 02, 2009 | Memorex Mega TravelDrive 4 GB USB Hard...
Memorex 160gb external hd
Hi and welcome to FixYa,
Sorry to be bringing you the bad news, but chances are, the Memorex is a goner. You could still of course try removing the actual/internal hard drive, connect it to an IDE/SATA to USB adapter and see if that in turn would be recognized by any of the computers. If yes, then it is the electronic/data interface of the Memorex that is defective. If likewise not also, then the actual hard drive is faulty. If the hard drive still spins and makes no mechanical noises, there is a slim chance that the contents could be recovered using file recovery software such as GetDataBack.
Good luck and Thank you for using FixYa.
Jan 03, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Evenflo Aura Traditions Travel System Safari Trek Stroller Logo
50 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
