Westinghouse LCM-19v1 Monitor Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need power cable for a westinghouse LCM-19v1 SL monitor
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Dec 29, 2009
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011128
Points
4641
We carry the power cords for this model at our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Verticle lines on monitor
Hi there.
I have written a very helpful tip about this problem recently.
Check it out here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
I have a Westinghouse LCM-19v1 SL monitor. The speakers are not working. I have the monitor plugged into the computer as well as the audio cable.
Let find out first if it is the powered speakers in the monitor problem or in the PC sound card problem.
Feed the monitor with sound source such as MP3 player to see if you do get the sound, if not, more likely to be bad speaker amps circuits problem which will not be worth putting the money to have it repair since you can spend the repair money on a good set of power speakers that will you so much better sound than the monitor built-in speakers about the size of a quarter.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
2answers
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
I have a Westinghouse LCM-19v1 SL monitor; uncertain of the year. A few days ago it suddenly went black. I've checked to make sure it's still plugged in; it is. The power button will not come on. Any...
More likely to be bad caps in the power supply, you will have to invest money in tools to do the repair.
Please read on so you will have some ideas if you want to fix it or not.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
2helpful
2answers
Westinghouse Model: LCM-17v2 SL DC Input : 19V === 2.6A S/N: W17C I need a power cord. Westinghouse Monitor Model:LCM-17v2 SL DC INPUT : 19V === ...
Hello Mike, you can order the adapter by calling the Westinghouse parts department at the toll free number 1800-701-0680 and selecting option 2 for parts. You can also send me a request for the part to [email protected].
2answers
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
2answers
NEED NEW POWER CORD FOR WESTINGHOUSE COMPUTER SCREEN MODEL LCM-17v2 SL. WHERE CAN i GET ONE?
Usually monitor cables are standard, and are the same as your PC. You may want to try the one from your PC see if that works fine, then you know exactly what to get.
2helpful
2answers
I have a Westinghouse LCM-19v1 SL that only stays on for a few minutes. Then turns blank screen. Then I have to reboot the PC to get it to turn it back on again. I tested the power supply of the monitor w/...
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If your problem is not the capacitors then it would be the backlights and that is much more difficult to replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Top Westinghouse Computers & Internet Experts
Paul Bade
NOEL
NOEL
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
