Question about Canon PIXMA iP4300 InkJet Photo Printer
Change Default settings - Canon PIXMA iP4300 InkJet Photo Printer
  • Anonymous Dec 12, 2008
    Can't set the PIP setting on my Monitor 910 MP
    Master:
  • 619 Answers
Open control panel , click printer Icon as yo wish to default , click eefault.
Posted on Jan 06, 2008
How do you change the default stitch length for the straight stitch.
A setting change while you are sewing should not happen. Sounds like you will have to take your machine in for service.
Apr 11, 2015 | Janome Memory Craft 9000 Computerized...
HOW TO SETT DEFAULT SETTING
Default setting should already be set, as default. Any changes you make will change the default setting. If you need to go back to default setting you can factory reset which sets back to default setting.
Default
Oct 14, 2014 | Cell Phones
Change default font in word 2013
Click File > Options > General. Change the default font in "When creating new workbooks"
Mar 29, 2014 | Computers & Internet
After downloading vlc all my icons change into vlc. how can i get rid off it?
Deselect the option to make VLC your default player. This should revert them back to normal. However if you want to play back the media files you will have to right click the file and select play via VLC. This will not change the icon of that file back to the cone of VLC, only changing to default will do that. If you were using Windows Media icons before, then selecting Windows Media player as default player will change the icons back. Normal clicking of the mouse on a media file will cause the play back via whatever player is set as the default.
Aug 12, 2013 | VideoLAN VLC
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
WRT310N
Hello I found the following info about the default settings on your router (you can reset your settings to the default ones by pressing the reset button on your router or the back of your router device):
Link is: http://pcsupport.about.com/od/linksys-default-passwords/a/wrt310n-default-password.htm
WRT310N Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Jan 28, 2012 | Linksys WRT Computers & Internet
I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
Jan 06, 2011 | HP Photosmart C7280 Printer
Windows Mail does not revert to default print settings
see if you have done change in ti or try to reinstall it!!
Aug 13, 2009 | Microsoft Office Outlook 2007 for PC
How to get off of current settings to default setting
press menu to get to system settings
use > to get to restore default
ok
Eric
Jun 20, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
Canon PIXMA  iP4300 InkJet Photo Printer Logo
111 people viewed this question
old marine
old marine
