Question about Pioneer PureVision PDP-503HDE 50 in. Plasma Television
Staining if tv is on or off there is a permanent stain on screen,it starts at bottom left and works its way up to top right hand corner like a hill,it is green in colour and noticeable when there is light back ground whilst tv is on any idears its too exspensive to replace screen.
  • 3 Answers
Your problem is probably overheating. Touch the screen where you see the stain. Is it very hot to touch? Is there a radiator nearby?
The only solution I know is to move the TV to a cooler spot.
Posted on Jan 25, 2009
Its not a magnet. I had the same issue. A circuit board needs to be replaced.
Posted on Nov 18, 2008
    New Friend:
  • 127 Answers
Ahh, that isnt good, the only reason I can say, is, the green stain your referring to, is result of a magnet, or magnetized object coming too close to the screen, thus pulling the color from the screen, depending at which point you put the magnet, it will either be green, red or blue. I dont believe there is fix for it.
Posted on Dec 28, 2007
Can someone tell me what the square footage is in a board 2 inches thick 8 inches wide and 8 foot long please
if you are staining the edges and both sides it will work out as follows
Each flat side is roughly 5.28 square feet or 10.5 square feet total per board.
The edges add rougly another 2.4 square feet so rough answer would be 13 square feet per board.
Jul 10, 2016 | Office Equipment & Supplies
There are 2 bright stains on the screen and low quality on Dish TV
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Dec 04, 2012 | Westinghouse 46" Class LED 1080p 120Hz...
Clean old wood
I would start by wiping It down with a damp cloth and then letting it try. Depending on its condition there are a few steps to take from here. One option for something in good shape would be a wood polish (though I don't think this is what you want for a work bench). If it needs more work, it can be sanded a fine grain sandpaper and then left as is, or stained or sealed. Just as a heads up, wood is very porous so if it is stained because something was spilled and left to sit, it's likely permanent. A dark stain (found at any hardware store) and some sanding might be able to over it up.
Mar 02, 2012 | Cell Phones
I spilled liquid on the HP 5610 scanner. Now I have a stain on the left margin of my scans. The stain is a strip that extends from top to bottom. How do I remedy this?
One way to remove all types of stains and fingerprints is Windex and a soft rag. That is one of the cheapest and easiest way to do it.
A better approach to it is to use monster cleaner. It is a special spray to clean tv screens, laptop screens, and even windows. It comes with its own cloth that works amazingly well. I have used it for years and has worked for me every time. You can pick it up at your local Best Buy or click on the link to buy online. http://www.bestbuy.com/site/Monster+Cable+-+TV+Screen+Cleaning+Kit/5774879.p?id=1069297113224&skuId=5774879&st=screen%20cleaner&cp=1&lp=1
May 06, 2011 | HP Officejet 5610 All-In-One InkJet...
On a light background a cloudy smokey stain is seen from bottom left to top of screen
you have a screen sepration failure you will need a new panel big buck
Nov 19, 2009 | LG 42LC3R 42 in. LCD TV
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
There are burnt on grease stains on my new ceramic glass kitchenaid cooktop on one burner. I've tried cooktop magic and it did remove some, but not all, stains. A razor was recommended to remove the...
Use the razor push only in one direction this will remove the stain. Ceran is a very resiliant material and you will not scratch it but if you leave gunk on the burner and repeatedly cook on it the stain will become permanant and you also risk pitting the glass. Pitting is pock marks in the glass that are permanant. Pitting is most commonly produced when starch or sugars are left on a burner but is possible with other spills. Good Luck.
Jan 07, 2009 | Heating & Cooling
Sharp Notevision XG-NV6XU
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Water stain on the front of our Akai PT5499 Projection TV
Hmm... should evaporate on its own. The only way to access behind the screen is to take the whole back off the TV, and then inside theres another panel that covers the main reflector and screen. I wouldnt recommend doing that just for water tho.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
Stain on screen
most of the time you wont get these types of stain out but sometimes they do come out. what i use is monster screen clean. if it doesnt come out you will need to replace the sreen. they usuall run from 75 dollars to 150
Aug 31, 2007 | Sony KP-ER43M61 43" Rear Projection...
Open Questions:
See all Pioneer PureVision PDP-503HDE 50 in. Plasma Questions
Pioneer PureVision PDP-503HDE 50 in. Plasma Television Logo
408 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
