Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Problem for Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-Air svd48600w chiming and displays f7 on
By csstocks on Oct 17, 2009
Jenn-Air svd48600w chiming and displays f7 on control panel and the buttons on the panel no longer work. The only way to make it stop is to flip the breaker, then it starts again after a few minutes. For the last couple of months, when I use the oven, after shutting it off, f1 has been popping up, but if you hit cancel it stops, now i've got the f7 problem. Please help
Solution #1
posted on Oct 17, 2009
Not Rated)
milten1
Rank: Guru  Jenn-Air Ovens & Ranges  Expert
Rating: 90%, 482 votes
http://www.appliancepartspros.com/part_details.aspx?image=0&part_id=4090068
whats happening her is that you are getting a stuck button error
it keeps happening because when you reset, the stuck button is still stuck and it gives you the error again
Maytag suggest replacing bothe the touch pad and the erc, but I have onle had to do both twice in the last 15 years,,,,
both had water damge
since you dont mention water , I would be willing to guess the part at the end of that link should be the only one you need to replace
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air SVE47100 Slide-In
Questions and Unsolved Problems for Jenn-Air SVE47100 Slide-In
Do you recommend Jenn-Air SVE47100 Slide-In Electric Kitchen Range?
Answer
Answer
when i try to turn my oven on it reads "feature not available" whats wrong with my over?
Answer
F I appears on screen along with a beeping noise after oven is turned off
Answer
all digital gauges are blank. Oven light works as does fan, burners.
Answer
Had to clean my oven because of a pie spill. Now a fan continues to blow and the oven won't turn on.... (More)
Answer
Trying to self clean oven F-9 code comes on with a beeping sound. What do I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air SVE47100 Slide-In...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
