Question about Standard (CRT) Televisions
Curtis mathis television picture
Hi I have huge circles all different colors in my picture what does that mean and can I fix it
2 Suggested Answers
SOURCE: curtis mathis universal control code for 13 in tv cm13102
We also bought a universal remote to program a Curtis Mathis TV. We found the code by using the code search method. It works everything but the channel program feature. Does anyone know how to access that? BTW the remote is a GE 24921. Thanks
Posted on Apr 26, 2008
  • 61 Answers
SOURCE: Is a Curtis TV the same as a Curtis Mathis TV
Curtis International Ltd of Etobicoke, Ontario is not Curtis Mathis, famous for building quality TV sets.
Posted on Sep 13, 2009
0 characters
1 Points
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Standard (CRT) Televisions
I can't access the advanced settings on my Curtis-Mathis TV
is it possible to connect my toshiba regza rv75 tv to the internet
Dec 15, 2013 | Curtis-Mathis CM19011 TV
Screeen color is green
This fault is called one color predominant screen. The cause might be to its video output card itself. There will be some loose solder terminals around the Green video output transistor. Check this card for any loose solder terminals. Just re-solder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjacent solder terminals. This card can be located at the neck of the picture tube [a rectangular board], will be directly plugged on to the back of the picture tube.
Dec 27, 2012 | Curtis-Mathis CM27101S TV
Tv_weight, curtis mathis 36 inch tube
The TV you specifies here [Curtis Mathis 36" picture tube type] has a weight of 150.3 lbs. OK.
Oct 19, 2011 | Standard (CRT) Televisions
Hi, As indicated by your model number the screen size is 27 inch, which is a common diagonal measurement. This TV has a standard aspect ratio of 4:3.
Jan 29, 2009 | Curtis-Mathis CM27101S TV
Curtis mathis 1982 model
Hi there!
It is probably the tube failing. Not a fault you can fix yourself without the right equipment and knowledge. Some repairers do have what they call a "Tube Booster". Fairly inexpensive to have done but not always successful. There is however a chance of burning the guns while boosting, so please do not hold anyone responsible for that. It will have to be done at your own risk or a new TV. Good luck, JUS004
Feb 28, 2008 | Curtis-Mathis CM32010 TV
Blue picture on tv
Have you tried cleaning the projectors and the reflecter? I have same model and it wont turn on. Email me if you still have this set.
Nov 19, 2007 | Curtis-Mathis Standard (CRT) Televisions
1986 25 inch Curtis Mathis console tv
I have a curtis mathis console tv with a 8track player, casset player record player and a am/fm stereo, mod number on the box is F607 style TC2 seril number 04787814 new in the box never opened. where can i find out its value?
Nov 18, 2007 | Curtis-Mathis CM27101S TV
Standard (CRT) Televisions Logo
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
