Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer
Problem for Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load...
No heat
By strummer897 on Oct 17, 2009
the dryer won't produce enough heat to dry clothes only cold air
Solution #1
posted on Oct 18, 2009
Not Rated)
james klgr
Rank: Guru
Rating: 87%, 240 votes
take off the back of the dryer you will see wires to the lint tube thats heating elements take the removeable plate off and see if its clogged with lint if so clean it out that should fix it if its not elements are probably bad. its also easy fix
Was this helpful?
Yes
No
Popular Solutions for Kenmore 3.8 cu. ft. HE3 King
Questions and Unsolved Problems for Kenmore 3.8 cu. ft. HE3 King
Do you recommend Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer?
Answer
Answer
Washer has a loud thumping noise on high speed spin, checked behind rubber gasket and the plastic... (More)
Answer
the rubber seal in the front became loose and the wire part came out - can i fix it? Replace the... (More)
Answer
My kenmore HE3 kingsize front load washer will not drain the water out. It will show an F2 error... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
