Rancilio SILVIAespresso&cappuccino machine
Problem for Rancilio SILVIAespresso&cappuccino machine
Silvia
By ron21 on Dec 28, 2007
got new machine --- first couple attempts produced shot in about 9 seconds, should take 25 --- as result, no crema, basically just coffee.
Same Problem
Feb 04, 2008
-   Coffee delivery is immediate not after a few seconds.
It rushes out too fast eg. 5 seconds for 30ml
No crema on top
-   kayebell
Solution #1
posted on Jan 28, 2008
Somewhat Helpful)
ardo
Rank: Apprentice
Rating: 70%, 1 votes
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Was this helpful?
Yes
No
Solution #2
posted on Jan 05, 2009
Not Rated)
atholchase
Rank: Apprentice
Rating: 0%, 0 votes
Maybe you are (a) putting in too coarse a grind - try grinding it much finer (you really should have a Rancilio Rocky grinder), or (b) you are packing it too loose. Try putting more coffee in. I fill it level with the top of the holder, then take off a small amount with my finger to produce a kind of downward dished surface. Then tamp it fairly hard. You need a HEAVY tamper for this.
Was this helpful?
Yes
No
Solution #3
posted on Jul 07, 2008
Not Rated)
ron the scot
Rank: Apprentice
Rating: 0%, 0 votes
I recently cleaned my rancilio silvia by backflushing. However, I forgot to flush the system afterwards (the boiler was on) and I think the cleaning powder has baked somewhere and caused a blockage because no water comes through the group head. I can get water out the steam wand OK. Is there a product that will dissolve? Not sure just descaling will work because there isn't an end to end flow. Anybody got any suggestions how I can remedy short of taking the think apart? I
Was this helpful?
Yes
No
Solution #4
posted on Feb 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I get recently roasted coffee at the local coffee shop and have them grind it past espresso to turkish. It creates a much better creme. Also, make sure you tamp the coffee in the porta-filter. I think 30 lbs. is recommended.
Popular Solutions for Rancilio
Questions and Unsolved Problems for Rancilio
Do you recommend Rancilio SILVIAespresso&cappuccino machine?
Answer
Answer
bought a durabrand espresso/cappuccino machine today, it does not have a users manual...can I... (More)
Answer
Does anybody have the technical manual for Saeco Office one coffee machine? I need the service error... (More)
Answer
I have a double 12 cup coffee pot by cook essential's. I just broke one of the glass coffee pots. I... (More)
Answer
dificulty to switch on the nespresso krups xn2001. seems that the on button does not make a proper... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and Espresso Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
