Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
KF50XBR800 Rear projection LCD TV on and then standby
Turns on, picture is fine. After 2 minutes shuts off and goes to standby. After another 1-2 minutes goes back on. Cycle repeats indefinately until I try to turn off TV then I get a series of 5 blinks on standby light which repeats and finally turns off
  • Anonymous Mar 30, 2014
    my sony rear projection lcd tv, when I turn it on it works fine then it will shut down and when this happens my standby light blinks green. then it will turn back on on its own and it keeps repeating the process. please help
    Guru:
  • 1,894 Answers
From how long you have this problem? and what made it start?
do u remember the cause?
Posted on Dec 28, 2007
  • 2 more comments
  • dewan nafees ahmed Dec 28, 2007
    most likely just a bulb failure...How many hours on the set? You should be up and running again when you install the new bulb.
    Check your owner's manual about the flashing light code. It may tell you some more about what's wrong
    the lamp replacement works most of cases.
    so that is your best solution.
    You have a bad lamp or the lamp circuit, called the ballast circuit is
    bad. If you have no solid state repair experience, contact a pro to
    assist you in this repair. This is not a set you need to replace a
    simple board on.
    If you have solid state repair experience here is the explanation for you.
    Five blinks - AKB circuit (automatic kine bias), the
    timer/standby indicator blinks for about 30 seconds then goes to the
    self-diagnosis function. Something is wrong with the video. Check video
    out, Q705, 732, 761 and other components on the C board, also check
    Q218, 219, 220 on the A board. In addition, unit could be in IK
    blanking, try turning up screen slightly.
    http://www.techlore.com/article/15444/Un...
    save this page and keep. it will help you in future.
    this has all explanation for blinking codes.
    but i thinnk they will be found on ur manual also i think
    http://www.user-manuals.com/advanced_sea...
    if u dont have a manual do download it and have one for you. even tough it costs a little, it will be useful for you for a very long time.
    thank u. that was my whole reply.
    tel me what works
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Picture goes off and standby light flashes then picture comes back on after a short time
Ur tv projection lamp on this tv been in it like a 1 1/2 or 2 years and daily used like 4 or 5 hours a day?Yes.Than the tv projection lamp life are ending.Require a new tv projection lamp.
Nov 17, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a sony LCD projection TV Model # KF-50XBR800 and when I go and turn it on my standby button flashes red and then picture comes on for about 10 seconds then it shuts itself off. Can you tell me what...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 28, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
I have a sony xbr lcd projection tv . it goes on and off all the time . like every two min . and the standby light comes on. model KF-50XBR800
Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Jul 16, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
What does it mean when my tv flashes standby? after like 30 sec
Since this is an Rear Screen LCD projection TV set it could be 1) Bad lamp, 2) Power supply issue.
I would check the lamp.
Blessings,
A/V Media Tech Guy
Dec 20, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Sony lcd projection tv kf50xbr800 shuts down and
Hey there, from what you are telling me I think the problem is coming from your Power Supply board it sounds like it could be two things
one: the board might have gone bad and its not sending the corresponding voltage to your components and that is why it keeps turning off
example: works ok for a while then gets weak truns off and then gathers enough turn back on
two: the power supply could be over heating and it has a sencor when it gets to hot to turn off this is very rear though
please rate this solution !!!
Jun 19, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Tv turns off after being on for 1 minute.
I assume its Sony DLP TV and symptom shows it is new lamp time.
Let me know exact model number to help you more info.
May 11, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Grand Wega picture going on and off; standby light flashing, sound remains on
Is the cooling fan running properly?  I'm just guessing, but it sounds like it could be overheating and shutting off, which allows it to cool off enough to turn on and overheat all over again.
Dec 09, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
252 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
