Question about Ovens
1988 General Electric Oven
Temperature Control problem following a Housecleaner cleaning this Self-Cleaning Oven. Now, for example, when set at 250F will burn items within 15 min. Is this a simple repairable problem or much worse ?
Note: No observed model number, only GE symbol
The broiler gets warm but not red.
Posted on Jul 20, 2008
  • 833 Answers
Sounds like the the thermostat. This is the dial item which controls the temperature. Removal and replacement is usually straightforward. Turn off the power before starting work.
Posted on Dec 28, 2007
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
How long does the oven stay lock after cleaning
It depends on the temperature in the house....but usually a few hours should be long enough for it to cool down...
Check this out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 04, 2011 | General Electric Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
I have an old Whirlpool Self-Cleaning oven. I've followed the use guide instructions but still can't get the cleaning light to come on. I have both knobs to clean but the oven light comes on and the...
Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
Jan 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Oven gets hotter than temperature set
I don't know if there is a solution but I kbow every model like this does the exact same thing. I two of my family members have the same stove and they have the exact same problem.
Oct 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE electric range with self cleaning oven. When
try to unplug power from wall and wait 30 min,then turn on
Jul 05, 2009 | Ovens
Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Dec 17, 2008 | Whirlpool RBS305PDS Electric Single Oven
    How to use self cleaning oven
    • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
    • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
    • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
    • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
    • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
    REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
    Nov 11, 2008 | Ovens
    Ovens Logo
    170 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
