Question about Kenmore 53793 Side by Side Refrigerator
Model 10644252401 I hope you can help. I have a side by side refrigerator. It's making way too much ice and frost. It's 3 years old. Any help? Thanks
catriver
  • 878 Answers
SOURCE: GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Posted on Apr 04, 2007
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
SOURCE: Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Posted on Apr 18, 2008
Hi, My Bosch Model B20CS50 SNI/01 side by side
It sounds like the fridge is in need of a regas, but that seems unlikely after only three years, although not impossible. An indication of that would be if the compressor could be heard to be running all the time. If it cuts out after running only a short time it could be the thermostat that has gone faulty.
Mar 23, 2011 | Bosch Appliances 20.19 cu. ft....
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Automatic ice dispenser on Kenmore side by side freezes up
Probably the trap door where ice dispenses out is not sealing tightly causing frost buildup
Sep 29, 2017 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
Jul 29, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Frost building up inside freezer.
Hi: Make sure your vents are not blocked by too much product in the freezer. When you changed the heater did you take a hair dryer to the back to make sure the initial blockage of frost and ice was removed as that will still block the air flow to the referigator, and cause frost to build? Also if the frost isn't in the back of the freezer but on the food it means there is a bad door seal. Usually the frost will look like snow flakes. The timers are on a circuit board now. And expensive. Ge makes an excellent refrigerator, but the parts are high in price. I hoped this helped. Jeff
May 31, 2009 | GE GSS23QSSS
3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT DEFROSTING, CAUSING BOTH SIDED TO GET WARM. ELECTRIC CHECKED OUT ON HEATER AND THERMOSTAT. PUT IN A NEW CIRCUIT BOARD. SAME PROBLEM. NEW BOARD MAKES...
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
Mar 10, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Layer of frost on the bottom surface of ice maker
during periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
J
Jun 13, 2008 | GE Profile PSI23NCR Side by Side...
Not making Ice
Best thing to do is make sure the paddle is free to move and not covered in frost. and if that doesn't work. Replace the Icemaker and you will be good to go.
Thanks,
Bill
Apr 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Jul 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore 53793 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
