Question about Konica Minolta PagePro 1350W Laser Printer
Not noticing paper
My printer has been sitting for about a year not being used. Last week i put new toner in it, cleaned it out with compressed air, and reinstalled it on my pc (windows xp) and put 8 1/2 x 11 laser weight paper in the tray.
The computer is sending print jobs to the printer but the printer is not noticing that paper is in the tray. I keep getting an error message saying load paper in the tray. I loaded in many different ways moving parts and the paper every which way but it still thinks it is empty. I emailed Konica Minolta and they said to make sure the springs are on the bottom of the printer, and they are.
Has anyone else had this problem? Any advice on how i can get this to notice that there is paper in the tray would be helpful.
I took an envelope, folded in the end to triple its thickness and placed it in the middle of the paper tray underneath the very last page. This pushed the center of the paper up more and it had no problem detecting or getting hold of the paper. Have to be sure the paper supply tray is full though. When it gets to the last five or seven pages it has difficulty again. It's a nontechnical fix, but it seems to work.
Posted on Feb 25, 2008
4 Suggested Answers
  • 9 Answers
SOURCE: changing toner in a konica minolta 2480MF
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2480MFUserManual.pdf
check page 92-101 in pdf or 82-89
hope this works
Posted on Nov 20, 2008
jassimkv1
  • 165 Answers
SOURCE: Konica Laser says no toners installed. How do you
Take the tonner catridge and shake it left to right and reinsert then it will be ok
Posted on Dec 20, 2009
  • 39 Answers
SOURCE: How do I print 8-1/2
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Posted on May 06, 2010
My IR2520 printer keeps printing papers with black horizontal lines everytime i replace the drum unit and the toner it works for only two weeks and again the same problem appears...
take printer outside of building and use a can of compressed air to blow any split toner out of toner cartridges area and from the insides of printer and around the rollers for the paper.
Compressed air can can be purchased from electronic hobbyist type stores. Had same problem with a laser printer and this was how I fixed it . Check toner cartridge is not leaking toner also .
Nov 22, 2017 | The Office Equipment & Supplies
Related t my Lexmark E232, I'm using a compatible toner but it put excess of ink in the papers. Then I bough a new original Lexmark toner, and when I put in the printer on two lights, from top the second...
Inspect the overall paper path for signs of spilled toner.Gently clean the contaminated areas with a soft cloth or compressed air.
If you need further assistance please contact Lexmark Technical Support Center.
Jan 24, 2011 | Lexmark E232 Laser Printer
I have a PIXMA IP6000D and it will not print out last two pink colours. Have put in new cartridges and deep cleaned several times, worked for a bit but now stopped again.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3. Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Mar 30, 2010 | Canon Pixma iP6000D InkJet Photo Printer
I am getting yellow spots on everyting I print. I
This is a laser printer and not an inkjet printer. Cleaning the "Print Head" isn't an option and putting alcohol on the printer's toner cartridge isn't the answer either. Minolta indicates that it is likely the yellow toner cartridge is bad. I have had a magenta toner cartridge exhibit the same problem. I just had to replace it which solved the problem.
Feb 08, 2010 | Konica Minolta magicolor 5430 DL Laser...
Printer won't print error message corona wire needs cleaning
When you experience a persistent problem like this right at the beginning - listen to your own good advice. Take it back to the store and exchange it for a new one.
Jul 30, 2009 | Brother HL 2140 Laser Printer
Print Cartridge Detected is the Wrong Type - error message!
It sounds like the contacts on the cartridge sensor need cleaning.
First remove the cartridge, paper and feed tray. Use compressed air such as "DustFree" or other brand of "canned air" to blow all of the dust and toner out of the cartridge well and paper path. Then, using a lint-free dry cloth, clean the metallic contacts where they mate with the contacts on the cartridge. Just gently rub them off to remove any dust and toner residue. Do not use any liquids or chemicals on the lint-free cloth. If you do not have a lint-free cloth, you may use a clean (read new) rubber pencil eraser. After using the lint-free cloth or pencil eraser, spray the contacts again with canned air.
Reinstall the cartridge and paper and verify that the printer returns to the ready state. If it does not, you need a certified HP technician.
Feb 04, 2009 | HP LaserJet 1200 Printer
Brothers HL 1240 Alarm light on
Pull the drum out the front door, remove the toner cartridge and check for any paper and remove it.
Make sure there is toner in the toner cartridge. Look at the lights on the printer. Look at the labels beside them. The label "Toner" will have two lines going to two lights. If those two lights are on when you try to print, you are out of toner. But a now toner and install it in the drum. Install the drum back into the printer.
If not, look at the drum. At the rear top is an opening across the whole drum. Look inside it, you will see a metal grid. That grid must be clean or it will cause small sparks. These sparks will cause a false toner empty error. Buy a can of compressed air from Best Buy (or wherever). Use this compressed air to blow clean the grid. Move the small blue tab at one side of the opening ti the other side and back again. Reinstall the drum and try printing again.
If neither of those help, write back and let me know what lights stay on when the printer stops.
Sep 06, 2008 | Brother HL 1240 Printer
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
252 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
