Need to change a right, back turn signal & brake light bulbs on a 95 Buick Skylark and not sure how to get to them.
Most car like yours require tail lamp removal to acces the bulbs, inside the trunk there will probably be some type of carpet light trim directly behind the lamp. You will either be able to fold it out of the way or there may be some type of clips that hold it. once the trim carpet has been moved you will have either plastic "wing" nuts or regular nuts to remove to pull the lamp away from the body (or you may have direct access to the bulb sockets) once the lamp is away from the body & the sockets are exposed, it is a squeeze and turn to remove the socket from the lamp. be sure to get the correct bulb - besure to re-assemble correctly or water leak may occur. the procedure may be outlined in your owners manual
PLEASE DON'T FORGET TO RATE!!!
Rear Turn Signal, Brake, & Marker Lights
On some vehicles, such as this 1986 Grand Am, you must remove the rear body panel with the lamp
Depending upon vehicle application, remove the lamp socket either by rotating it counterclockwise (approximately 1/4 turn) until the plastic tabs disengage, or by squeezing the metal tangs while pulling the socket from the light assembly
Remove the lamp socket assembly by turning it counterclockwise, then pulling it out
Generally, side marker lamps use small bulbs with flat, blade-type bases, and tail lights/turn signals use larger, round-based ("bayonet") bulbs.
Remove the side marker bulb from its socket by pulling straight out
To install:
Cant help here i can give you a diagnosis but iam in spain and have no product knowledge of many american cars.Most vehicles have to big plastic knobs in the boot to allow the light cluster to come out ,or a screw or two on the side,Sorry
