Question about Whirlpool GHW9300 Duet Washer
Door Locked after FA code
Duet GHW9300 front loader was turned on when the water supply was off. It flashed FA code. The cancel was pressed 2 times and unplugged but the door is still locked and it sounds like it wants to add water (sort of a humming noise). It is responding to changing the cycles but it won't cancel of shut off and the door is locked. I need my clothes! Any suggestions or help would be appreciated. I am a computer technician and mechanically handy.Thanks
  • Breaz Dec 28, 2007
    Sorry the washer flashed FH code.
    President:
  • 1,294 Answers
Press "end of cycle" button and wait for a click or 3 minutes, they try the door. Do not force door
Posted on Dec 29, 2007
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer was running doing load and heard a solid beeping the h and f were flashing on panel heard pump sound like it was working but machine had already drained water unplugged and waited plugged in socket...
This error code means"No water detected entering machine or Pressure switch trip not detected".
Is the machine getting any water? Check that the water supply is turned on.
Press pause cancel twice to clear the display.
Try to run another cycle.
Let me know if I can help with anything else.
Mar 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I recieve a 02 F code on my Duet front loader
02 means = Long Drain
Solution -
  • If the above does not correct the problem, replace the pump.
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not restart after adding clothes
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. Wait for 2 minutes before trying the door. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Apr 19, 2009 | Whirlpool GHW9300 Duet Washer
Whirlpool duet dryer
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Duet Front load Washer - will not start cycle.
Does your front washer, every time you press cancel give you a code that looks similiar to ER?
I checked the description and for some reason whirlpool denies having a F22 code on the Duet, but that doesn't mean much.
I am suspecting several things.
1. Electrical supply may have had a surge at one point or another. You may have to ask your electrical company to put a surge protector on your house by the meter. This is not to protect everything it has its own limits!
2. Unplug the machine for a while. Turn off the water supply and disconnect hoses The machine knows if there is water coming into the machine by a trip sensor.
3. drain out your exhaust line. There is a possiblity your machine thinks you are full of water when it is actually empty.
4 put everything back on, and then plug machine back in after about an hour or so. If it still doesn't work, it is time for your local appliance repair service technician to come out. He will check door trip sensor, and a few other areas that may be acting up.
Good luck.
May 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
199 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
