Question about Electrolux EOC6690X Pyrolytic Electric Single Oven
Electrolux EOC6690X Pyrolytic Door won't close properly
The door of my oven won't close properly as the switch, which is located on the upper left hand side, doesn't seem to engage correctly. As such, the fan oven won't heat up. Any suggestions as to what might be causing this?
  • 1,314 Answers
If the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Posted on Dec 29, 2007
Why is my electrolux oven is ringing non stop after using pyrolitic cleaning
Hello Avishag, thanks for your post!
From what you have described your Electrolux oven is ringing after you have used the pyrolytic cleaning. Your control panel may need to be reset and you can do that by disconnecting power from it for at least ten minutes. If this does not help resolve your issue I would need your model number to further assist you. You can locate that information on the frame of the door on a white or silver tag. Once I have that information I would be happy to assist you further. -Matt
Apr 11, 2016 | Electrolux Ovens
How can I open a stuck oven door after running the cleaning programme?
Did you release the lock on top of oven door? Oven would not start cleaning until this lock is in place.
Mar 23, 2016 | Ovens
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
I have burnt on food (sugar) in my Miele pyrolytic oven. How do I get it off? Will using the pyrolytic process just make this worse?
Ammonia works really good to remove burnt on food. For inside the oven put a small bowl of ammonia on the rack, close the oven door & let sit overnight. The fumes will work overnight.
Dec 01, 2017 | Ovens
When the pyrolytic function is switched on the oven starts the process then after about ten minutes the code f1 appears on the digital control panel and stops
Hello katefreeman1 - Typically error code F1 indicates that the range has detected an issue with the runaway temperature (overheating). A certified technician will need to check the RTD sensor probe and/or EOC and replace if necessary. Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart range. Usually this will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately.
Jan 22, 2013 | Electrolux EOC6690X Pyrolytic Electric...
GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
Oct 11, 2017 | GE Profile JT980 Electric Double Oven
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
May 26, 2011 | Ovens
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Electrolux EOC6690X Pyrolytic Electric Single Oven Logo
726 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
