posted by euho on Dec 28, 2007
I get the error message "No power to LNB" on my motor home dish. The dish come up and rotates but then does the emergency store. The manual says disconnect power to receiver then resore. I have done that but it does not help. It says replace the receiver. Is there a way to check to see if there is power coming out of the receiver?
Comment by euho, posted on Jan 12, 2008
Thanks for the suggestion on how to check the receiver. The receiver checked out okay. It appears the LNB may be bad since the receiver is putting out the correct voltage.
Best Solution
posted on Jan 10, 2008
Use a multimeter set to DC, positive to center conducter, negative(ground) to outside of connector. Should read about 13-18V.
Rating Locked! (?) euho has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for RCA DRD480RE Receiver
Email this problem
Email this problem
Can you Help with these Receivers problems?
RCA DRD430RG satellite receiver...
I have a RCA DRD430RG satellite... Answer This...
Repair Service
Find Receiver Repairman Near You:
Find Parts
