Question about ASUS A8N32-SLI Deluxe Motherboard
Flight sim 2004 not happt with SLI configuration
Merry Christmas.
I have had to remove one of my G.Force 7600 GT Cards [ 2 installed Sli Connection attached} in order to get my flight sim {FS9] to run without blue screening. Reports a graphic driver issue, but I have latest drivers but problem still persists, unless I remove one Card,
    President:
  • 2,351 Answers
Check page 2-19 section 2.5.6 of your manual. Also
Page 2-32
If this is all correct than swap known good card to second-PEG unsued slot. You could have a bad video card or SLI cable.
Posted on Dec 29, 2007
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
Hi can i install evga gforce 9500 gt video card
Yes, it will work just fine. Just make sure you uninstall the drivers of the embedded one before installing the new one and you disable it from the BIOS immediately after.
Apr 18, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Need m2n sli drivers..help?
Your SLI drivers as you mentioned were installed when your chipset drivers were installed. (NVIDIA nForce CK804 Chipset Driver).
If you use 1 PCI-E graphics card the bios will need to be adjusted to [Auto].
Using 2 PCI-E graphics cards you must install the EZ selector card correctly. See page 4-20 section 4.4 Adjust; SLI Configuration. Than see section 4.4.6 in your manual
Open the Asus link below if you need drivers for your M2N-E SLI;
http://www.asus.com/Search.aspx?SearchKey=M2N-E%20SLI
This may seem a bit tricky but its not. First time around the bios settings using SLI graphics cards will appears tough but you'll get it.
Cheers!
Mike
Oct 16, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Sli will not activate....... Vista 64 ultimate , 6 gigs of ram, 2 xfx 9400gt 1gig, amd phenom quad 2.5 , asus m2n sli deluxe
Hello raidon1449
Have you accessed BIOS(startup and start tapping F2) to see if SLI and not PCIexpress is selected?
The best thing that I can recommend with any SLI or Crossfire setup is to install the cards seperately at first to make sure they are working by themselves. Then install the cards in SLI or Crossfire configuration.
Jul 09, 2009 | Computers & Internet
SLI
Make sure you have installed the latest Nvidia drivers. Get them from Nvidia's web site, not the included disk. Make sure "Enable SLI" is selected in Nvidia control panel. Re-seat both cards and the SLI bridge. BTW what Mobo do you have?
Jan 06, 2009 | MSI K8N Neo4 Platinum/SLI Motherboard
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
SLI Video Cards
Enter you're bios & open you're manual to page 4-32. Set you're
configuration to dual video card. Use the AL software to tweak you're settings in windows. If you find this not helpful than please call Asus tech at: 1-812-282-2787, M-F 8:00AM-5:00PM EST. Unlike other companies you will not be on the phone very long. Please have the S/N of the board handy. This is located on the board, on the LTP port (White sitcker).
Good Luck!
Mike
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Vista ultimate - Second card doesn't have enough resources???
thats 64 bit for ya.. welcome to buggy driver "if they support (beta)it"..
chipset, then video driver.. also vista has UAC issues. right click install as admin. good luck (i dont like vistuh)
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Sli 8600gts cards on mobo
maybe you need a higher wattage Power Supply. try decreasing the load like removing optical drives and extra HDD.
Sep 14, 2007 | Gigabyte GA-8N-SLI Motherboard
ASUS A8N32-SLI Deluxe Motherboard Logo
190 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
