Question about Starbucks Barista Utopia
My coffee tastes weak
I received a Keurig machine for Christmas and it's really convenient and the coffee smells strong but tastes weak and it wasn't like that the first few times I used it. Can you help?
  • Starbucks Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with a bad burnt taste.
Posted on Apr 01, 2009
How do I remove the bad Plastic Smell & Taste from my Keurig B70 Platinum coffee brewer?
That should not happen. Return for a replacement. The heating resovour may have factory material in side the unit.
Jan 21, 2013 | Keurig Platinum B70 Coffee Maker
Keurig drinks taste bad like plastic
try running viniger threw it then flush it out
Aug 29, 2012 | Cars & Trucks
Coffee has a bitter, plastic, toxic taste. Even after cleaning and running many cups through new machine
Debris was left in the chamber when manufacturing the unit. Flus and clean accordingly and it will survice.
Dec 27, 2011 | Keurig Special Edition B60 Coffee Maker
Coffee is really bitter and doens't taste good
hmm well it wouldn't surprise me. I'm glad you were able to get to the bottom of it! ;) have a great day and enjoy your Keurig!
May 26, 2010 | Keurig B60 Coffee Maker
Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Sep 13, 2009 | Keurig B70 Coffee Maker
Keurig new with burnt plastic smell
We had the same problem with the Keurig 2.0. We ran many cups of vinegar followed by water and it didn't fix the problem at all. The only fix was calling Keurig and they replaced the unit. We had a real nice 460. They replaced the unit with an inferior 350. Smaller reservoir, B&W screen and some missing menu options and different color trim. However, it works.
May 28, 2009 | Keurig B60 Coffee Maker
Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Dec 27, 2007 | Keurig B50 Coffee Maker
Coffee Makers & Espresso Machines Logo
656 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
