Question about Kenmore 72012 / 72014 Kitchen Range
Self clean will not start
I press the self clean button and select the soil level. Then press start and it sounds like it runs through a cycle because I hear a click noise every few seconds. It will cycle like this several times and then the display reads "E1 F5". The owner's manual doesn't mention this code but for another code it says to check the door switch plunger. this plunger seems to be working fine.
E1 f5 is saying your door latch is not operating will either be the switch or the latch motor or the latch itsself is out of line and not going into the slot to latch the door depress the door switch then do clean keeping your fnger on the door switch at all times observe if the latch comes out or not if it does its out of line if not its the motor or the switch still keeping your finger on the switch hit cancel
Posted on Dec 28, 2007
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How do I repair a Cabrio washing machine
    Press the cancel button all indicator lights/LED should be off
    Select any button except Power, Start,Pause/Cancel
    e.g. select buttohttp://www.fixya.com/answer/answerpageslideview.aspx?thid=25219265&ctg=130n "Soil Level"
    Press "Soil Level" button and hold for 3 seconds
    Release "Soil Level" button wait for 3 seconds
    Press "Soil Level" button and hold until "88" lights up on the display and all indicator lights turn on
    Watch the display flash any error codes will be displayed. e.g. "81" , "F", etc
    Take a note of the numbers and letters displayed, press the "Soil Button" and the next set of codes will be shown. Press the soil button a few times noting down all the codes until "88" is displayed.
    If the "Soil Button" doesn't work try another button using the same procedure above exluding any of the buttons mentioned above.
    Please post the error codes you have noted.
    Oct 13, 2014 | Washing Machines
    How to use the self clean feature for a Frigidaire FES 355 ASF
    Hi Anonymous, this is AP!
    I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
    Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
    In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
    Best of luck,
    Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
    Lost Manual and would like instruction on how to set for self clean cycle?
    Make sure you have everything out of the oven, including the oven racks.
    1. Press SELF CLEAN.
    2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
    3. Press START.
    The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
    displayed.
    4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
    indicator lights will turn off.
    5. When the oven is completely cooled, remove ash with a damp cloth.
    Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
    If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
    It is also recommended that you remove anything plastic from the top of the stove during cleaning.
    Nov 27, 2010 | Whirlpool RF263LXTQ Range
    Does not go into self clean only beeps
    here is a link for your owners manual click here
    To set Self-Clean:
    2. Press the appropriate Clean pad.
    • CLEAN flashes.
    • SET and UPPER or LOWER flash in the display.
    3. Press the Autoset pad.
    • “MEd” (Medium Soil, 3 hours) is displayed.
    4. Press the Autoset pad to scroll through the self-cleaning
    settings.
    “HVy” (Heavy Soil, 4 hours)
    “MEd” (Medium soil, 3 hours)
    “LITE” ( Light Soil, 2 hours)
    Choosing the soil level of the oven automatically programs
    the self-cleaning time.
    5. After four seconds, the oven will start cleaning.
    • If the door is not closed, beeps will sound and ‘door’ will
    display. If the door is not closed within 30 seconds, the
    • CLEAN will appear in the display.
    • LOCK will flash in the display. Once the door locks,
    LOCK will remain steady.
    • The cleaning time will start counting down in the
    display.
    Please take the time to rate this solution
    Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
    Whirlpool Flat top Accubake self clean 24 inch
    Of course - Empty the oven and clear off around it.
    The AUTO-CLEAN cycle time is adjustable, from 2 hours
    30 minutes and 4 hours 30 minutes in 15-minute increments.
    Suggested clean times are 2 hours 30 minutes for light soil and
    4 hours 30 minutes for heavy soil. The last 30 minutes of the
    cycle is for cool down.
    To Self-Clean Using AUTO-CLEAN
    1. Press AUTO-CLEAN.
    2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
    desired self-clean cycle time.
    3. Press START.
    The oven door will automatically lock. The “DOOR LOCKED”
    and “CLEAN” indicator lights will be displayed. The time
    remaining will also be displayed.
    the “DOOR LOCKED” and “CLEAN” indicator lights will turn
    off.
    5. Once the oven is completely cooled, remove ash with a damp
    cloth.
    To Delay Start Self-Clean Using AUTO-CLEAN
    2. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired self-clean cycle time.
    3. Press START TIME.
    4. Press the TEMP/HOUR “up” and “down” arrow pads to set
    the desired start time.
    5. Press START.
    The oven door will automatically lock. “DOOR LOCKED” and
    6. When the self-clean cycle is complete and the oven cools,
    off.
    7. Once the oven is completely cooled, remove ash with a damp
    cloth.
    Owner, Warranty, Installation and Parts manuals are here:
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
    Sometimes search links don't work when copied.
    Here is the direct link to the Use and Care Guide:
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
    Page 16 has the above instructions.
    God Bless!
    -Ptochos
    Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
    Self cleaning
    You can go to the Maytag web site and download the manual.  www.maytag.com, or go to http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
    and download the manual CAUTION
    • It is normal for parts of the ovens to become hot during a self-clean cycle.
    • To prevent damage to oven doors, do not attempt to open the doors when LOCK is displayed.
    • Avoid touching doors, windows or oven vent area during
    a clean cycle.
    Do not use commercial oven cleaners on the oven finish or around any part of the ovens.  They will damage the finish or parts.
    Do not leave baking/pizza stone in the oven during self-clean.
    The self-clean cycle uses above-normal cooking temperatures
    to automatically clean the oven interior.
    The oven should be cleaned regularly by wiping up spillovers
    to prevent excessive smoke and flare-ups.  Do not allow a
    heavy build-up of soil to accumulate in the oven.
    During the cleaning process, the kitchen should be well
    ventilated to get rid of normal odors associated with cleaning.
    Before Self-Cleaning
    1. Turn off the oven light before cleaning as the light may burn out during the clean cycle.
    2. Remove broiler pan, all pans, and oven racks from the oven.  The oven racks will discolor and may not slide easily after a self-clean cycle if they are not removed.
    3. Clean oven frame, door frame (area outside of gasket, and around the opening in the door gasket) with a nonabrasive
    cleaner such as Bon Ami* or detergent and water.  The self-cleaning process does not clean these areas.  They should be cleaned to prevent soil from baking on during the clean
    cycle.  (The gasket is the seal around the oven door and window.)
    4. To prevent damage, do not clean or rub the gasket around the oven door.  The gasket is designed to seal in heat during the clean cycle.
    5. Wipe up excess grease or spillovers from the oven bottom. This prevents excessive smoking, flare-ups or flaming during the clean cycle.
    6. Wipe up sugary and acidic spillovers such as sweet potatoes, tomato, or milk-based sauces. Porcelain enamel is acid-resistant, not acid-proof.  The porcelain finish may discolor if acidic or sugary spills are not wiped up before a self-clean cycle.
    Important:
    • Oven temperature must be below 400° F to program a clean cycle.
    Only one oven can be cleaned at a time.
    • Both oven doors lock when either oven is being cleaned.
    To set Self-Clean:
    2. Press the Clean pad.
        • CLEAN flashes.
    4. Press the Autoset pad to scroll through the self-cleaning settings.
    Choosing the soil level of the oven automatically programs the self-cleaning time.
        • If the door is not closed, beeps will sound and ‘door’ will display.         If the door is not closed within 30 seconds, the self-cleaning       operation will be canceled and the display will return to the time of day.
        • LOCK will flash in the display.  Once the door locks, LOCK will
          remain steady.
        • The cleaning time will start counting down in the display.
    Nov 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
    Trouble starting Cycles
    Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
    Nov 13, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
    Kenmore 72012 / 72014 Kitchen Range Logo
    142 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Sal De
    Marvin
    Marvin
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
