Question about Tascam DP01 All-In-One Recording Package Microphone
If anyone can help me out,please do!
I just purchased the TASCAM DP-01FX Digital 8-Track Port Studio x/FX Process and i was wonderin if i could get instrumentals from my computer to the tascam on two channels,if i cant do that then its useless!
    Novelist:
  • 189 Answers
Alternatively you could load your stereo instrumental track into a wav editor, then export each stereo track as a separate mono wav file which you can transfer via usb into you DP-01 and then on you DP-01 import those wav files into two separate tracks which you can pan hard left and hard right so they are in stereo.
Posted on Jan 03, 2008
Ok i have 8 traks i want i need a master back up so i dont loose in simple term how to make a disk copy what i have thxs JB151
Posted on Mar 04, 2011
  • 36 Answers
On your PC's Sound Card, you should have a Line-Out connector (or you can use your speaker output - just use your sound card's audio adjustment tools to change this to a "Line Out").
You will need a cable from radio shack (or online) that converts the Stereo Mini (1/8") male connector into two 1/4" male connectors (unbalanced). These can be plugged into the front of the DP-01FX into the 1/4" plugs (where the Manual calls for Synthesizers/CD players).
Then, press and hold the ASSIGN key for the LEFT channel, and press the REC key for the track you want to be the LEFT channel. The REC light will flash rapidly to indicate successful routing. Do the same for the RIGHT channel. This will allow you to record instrumentals from your computer into your studio-in-a-box, and later add vocals through the mic inputs.
Posted on Dec 30, 2007
TASCAM DP-01 won`t startup
Press and hold down the "track edit" and the "shut down" buttons while turning the power on until it says "-init screen- please wait". It will ask you if you want to initialize hdd. If so press yes/enter. This Will wipe your hard drive clean. If no just press no/exit. This works on the dp-01fx. It should work on the dp-01 as well.
Dec 02, 2014 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Why does the screen read "device error" when I turn it on?
http://is.gd/B05L6B
According to the user manual for the device, on page 81, it reads:
If any of these errors occur, turn the the unit power OFF and restart it.
If these error message continue to appear, please contact a TASCAM Service Center.
***Device Error*** (the one you're asking about)
FileErr
FX Busy
FX Rx Failed
I
/F Error
Mount Error
SaveParam Fail
SD-Card Error!
SD Not Found
SD Read Busy
SD Write Busy
Looks like your unit may require servicing at an authorized Tascam service center.
Good Luck!!
Oct 12, 2013 | Tascam DP-03 DP03 8-Track Digital...
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
I need a driver for a Tascam DP-01FX
ok first i just wanna prepare ya on how bad your gonna kick yourself on this one, i have a used one and dont really use honestly i hate it...but i decided to mess around with it and decide to get sumthing decent and bring it to the comp for the first time...and i seen i had the same issue.. and saw that alot of people did to and they went on and on with no solution...so i gave myself 5mins to think and remember....and here ya go you ready... after you save all your songs correctly to get them ready for export...step 1.plug it into your usb port...step 2. ignore the fact that its not being noticed by windows...step 3. go to menu on ur tascam scroll down to disk hit yes/enter.step 4..now ur in the disk menu and right there the third choice..usb open/close hit enter and there ya go you will be prompt to open the usb port and everything is done your ready to go...when ur done u close the port...basicly an on and off switch for the usb port...i hope it helps and its not too late...good luck..oh it should be in the manual under usb...thats how i remembered it cause i remember reading it.
Jun 07, 2009 | Tascam DP01 All-In-One Recording Package...
Could you please tell me the simplest way to record a backing track off a cd onto the hard drive of the Tascam DP-01FX/CD and then add vocal and other percussion onto this track. I bought the unit...
Just review the manual guide,everything is there; in how to record.
If happens if you don't have it,just click below..
Sponsored Links Tascam Manuals on Retrevo
Free download of manuals from the
largest collection on the web
www.retrevo.com/Tascam-manuals
Aug 10, 2008 | Tascam Audio Players & Recorders
DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Jun 18, 2008 | Tascam DP01 All-In-One Recording Package...
C.d tray
Hold down "Shift" and press "Exit" at the same time.
Nov 12, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
194 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
