Question about Adcom GFA-5400 2-Channel Amplifier
Adcom GFA-5400 installation
There is only one set of speaker outputs on this amp, can I hook up multiple speakers to the single set of terminals or do I need to use something like a Niles MSA-10A. The only issue that I have with it is that I fear that sound quality will suffer, plus I have two sets of small Energy speakers and then a larger pair of MKs that I want to hook up. How do I hook up a sub to this?
  • TSWisla Dec 29, 2007
    Will the Niles compromise sound quality?
Posted on Jan 13, 2009
  • 54 Answers
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
Posted on Dec 29, 2007
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
I'm running two sets of speakers thru a gfs3 powered by a gfa 5300. the main speakers are on 1, the second room pair on 2. the speakers on 2 will only play when the main speakers are engaged. i recently...
Do you mean Adcom? That detail matters.
Register and download the manual for free at
That would mean you're trying to run two rooms with paired mono speakers and a different channel in each room. MMmm, okay.
It's a 2-channel power amp and it isn't really designed for the probable very low imedance you're providing with paired speakers on each terminal. And it has no ability to turn either channel on or off short of denying it a program input on either channel.
Perhaps if you ran one speaker from each channel into each room (impedance permitting), you would have two rooms with traditional 2-channel audio.
Mar 22, 2011 | Audio Players & Recorders
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Whent turn up the valume sound whit no power
I would contact Adcom for a service place near you
Feb 17, 2010 | Adcom GFA-5400 2-Channel Amplifier
Convert a 4 om amp to play w/8 om speaker
Connect the two speakers in parallel. That will present a 4 Ohm load to the amp.
Sep 14, 2009 | Adcom GFA-5400 2-Channel Amplifier
Adcom GFA-5002 is dead no lights, no anything
Check the Fuse. Unplug the AC first. If you replace the fuse and it blows again, disconnect all speakers, replace the fuse and turn on. If the fuse does not blow, chances are it is a speaker problem, Adcom builds some very solid product, I would suggest pulling the outdoor speakers and testing them.
Depending on what you are using, some outdoor speakers should never be taken out of the living room. If you still have an issue post a comment and I will help some more.
Jun 24, 2009 | Adcom GFA-5002 Amplifier
How do i bridge an adcom gfa 5400
This amp is not designed to be bridged and can not be used in the mode you wish. Sorry, but internal circuit changes would be necesary for the amp to work as a single channel.
May 01, 2009 | Adcom GFA-5400 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
Adcom GFA-5400 2-Channel Amplifier Logo
279 people viewed this question
Top Adcom Audio Players & Recorders Experts
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
