Question about Royal 85X Shredder
Shredder stopped working
It powers on fine...but wont shred...basket is in properly & basket light works,when pulled out.
    Scholar:
  • 102 Answers
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pcshredder stopped working - 1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
Shredder comes on fine but wont feed
Do you mean it won't pull in papers to shred? Could it be that your basket is full and needs to be emptied? Perhaps the shredder is jammed and needs to be cleaned out.
Jun 23, 2018 | Shredder Office Equipment & Supplies
Why can't I shred when using another shred receptacle for the shred
There is a switch that the original basket trips when it is installed. IF you don't use the original then the switch wont close and the unit wont start.
May 06, 2016 | Office Equipment & Supplies
Clogged won't run
Simple UN CLOG But turn of Power first
Mar 17, 2015 | Office Equipment & Supplies
I emptied the bucket of my shredder and now it doesn't run. It is only about 1 year old and isn't used much.
Check you have replaced the top on the basket properly, is it the right way round? If not on properly it will not feed power for safety!
Dec 29, 2014 | Shredder Office Equipment & Supplies
Shredder stuck, no power light, but power strip works
shredders do not have a long life time and are finicky. You have to pull all the paper out of the shredder to unjam it. I have trashed several. Be careful to not exceed the page limit as to how many pages it can shred. This is the primary cause of jamming. Also, using some light weight oil (3 in 1, for example) should be part of routine maintenance. good luck darlin
Sep 15, 2017 | Fellowes Office Equipment & Supplies
Don't know how to open the basket
If the basket does not slide easily out of the shredder cabinet it maybe "jammed full" of shredded paper which is preventing the basket from sliding out. There is a clear concave "handle" on the front of the basket which users should reference to determine the fullness of the basket. I pulled out and pressed upward on the "handle" it easily popped in towards the basket. From there it was possible to remove enough of the shredded paper to allow the basket to slide out. WARNING: UNPLUG THE MACHINE AND REMOVE THE PUPPY FROM THE ROOM.
Dec 12, 2010 | Royal PX1000MX Shredder
'Full light' blinks on and then off when you replace shred basket. Aurora AS1712x shredder. It's not full, won't work at all.
The sensor or button that tells it it's full, probably has paper dust or something jamming it. Clean it up without liquid and it will probably work.
Apr 24, 2009 | Office Equipment & Supplies
PS-70-2 not working
Make sure the pull-out wastebasket is all the way in. Also, make sure the basket is less than half full. A paper jam could also cause this symptom.
Jan 22, 2008 | Fellowes P70CM Shredder
Royal 85X Shredder Logo
815 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
