Question about Whirlpool Duet GHW9150P Front Load Washer
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
I HAVE A CODE ON THE WASHING MACHINE THAT FLASHES A F THEN 01. I HAVE UNPLUGED, CHECKED THE SCREENS IN THE WATER LINES. THEY ARE CLEAN. REPLUGED AND HIT THE START BUTTON AND KEEP RECEIVING A ERROR CODE FOR F 01. NEED HELP
  • pencil2 Dec 31, 2007
    Hi Tech 17,
    I did as instructed by you and the code keeps coming up. Now do I unplug the machine and then push pause cancel or do I start the machine push pause cancel twice because if I push pause cancel it turns the machine off. No results thanks so much. How is a diagnostic mode done?.
I had an F-01 error code on my 2 yr old Whirlpool Duet washer.
My wife said she opened the door too fast and thought she broke it. I had to pull off bottom panel and reach up to open manual door latch which is inside the washer. You can feel it up in there - a plastic ring that you pull down and you can hear the door latch pop open up.
The door would not lock then when trying to restart the machine and the same F-01 error code kept popping up. So I very lightly jimmied the door latch spring with a slot head screw driver being careful not to scar the plastic. I thought the latch may have been jammed.
I also cleaned out the drain - found about $2 of quarters; a screw; and some other small things like cheap jewelry stones (I hope they were cheap cuz I threw them away) plus also 5 inch length of grass trimmer line. Not sure if this was the source of error code if perhaps the pump was jammed.
Unplugged it for five hours, and now it works!
Posted on Jun 09, 2008
    President:
  • 1,314 Answers
You push pause /cancel twice with code displayed push push you can take off the topoff teo torx screws in back and there is a tech sheet there i beleive or under the bottom front plate gives you diag procedure but put it back so it dont get lost
Posted on Jan 02, 2008
  • 36 Answers
A power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Posted on Dec 28, 2007
Whirlpool duet sport flashing code f 01. how do I fix?
F01 is a failure of the main control board.you can try unplugging the washer from the wall for 10 mins and restart again. If the code comes up again then you have to replace the main PCB
May 26, 2016 | Whirlpool duet Washing Machines
Whirlpool duet sport front load washing machine
F-01 is a communications error between the CCU and EEPROM. The first thing to try is unplugging the machine for 5 or 10 minutes. If that doesn't fix it, you'll need a new CCU (probably need to replace that anyway). Though if you just got it 2 days ago, call the store you bought it from - they should replace it (and help you get it open to get your clothes out).
Sep 07, 2007 | Washing Machines
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fault code f-33 on a whirlpool duet.
The F33 code is a pump failure code. The control unit is not measuring the proper amp draw on the pump during pump out. Remove lower panel and unplug then replug in the pump 2 or 3 times to remove any corrosion. While your down there, take the front of the pump off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE SERVICING!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW00 stops after spin cycle
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2010 | Whirlpool WFW8300S
Whirlpool Duet GHW9150P Front Load Washer Logo
404 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
