Question about Meade ETX-70 (240 x 70mm) Telescope
Slew problem my etx-60 will only slew down but won't slew up...can hear motor running...any ideas?
  • itrait Feb 01, 2009
    I just got this out of the box and it didn't work from the start. This is the second product from Meade that has had problems. I'm really getting sick of throwing money away on products from this company. And I get no solution from the company.
  • 3,186 Answers
You did tighten the DEC knob? If you did the altitude gears (a worm gear) is not engaing properly. You can either return it to Meade for repairs or attempt them yourself.
I would also check that you have fresh batteries and that the UP button on the hand controller is not broken.
Posted on Jul 31, 2011
I have an ETX 80 and the motor runs but does not raise the tube, it lowers it and it slews left/right. Any ideas as to the problem. Many thanks in advance!!!
Is the clutch knob tight? If it is then something is broken inside the DEC clutch, causing it to slip.
Meade can repair these -- call customer service:
http://www.meade.com/support/index.html
Feb 21, 2011 | Meade ETX-80AT (240 x 80mm) Telescope
My telescope is only slewing at the max speed. as soon as i change it to another speed it will now slew??
Either the buttons are STICKING on your hand controller, or the hand controller cable is defective.
Contact Meade customer service:
Aug 30, 2010 | Meade ETX-60 AT Telescope
First time using the mead etx 60at. I turned it on and set the date / time / enter. Then set it at north and horizontal,enter. It asked if i wanted the easy alignment, I said yes. I said searching. Then it...
Did you lock down BOTH clutches?
You should have Calibrated motors and trained drives before you actually tried to do a goto.
Read this manual completely:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-60-70AT%20manual.pdf
Aug 21, 2010 | Meade ETX-70 (240 x 70mm) Telescope
Meade ETX-60 Horizontal drive
The AZ worm gear is not engaging the gears. There is a spring next to the gear which applies pressure -- open up the base and see if the spring is loose or broken.
May 23, 2010 | Meade ETX-60 AT Telescope
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
MY ETX-60 DOES NOT MOVE UP AND DOWN !!!!
Go to the Mighty ETX web site for disassemble instructions--
http://www.weasner.com/etx/menu.html
Apr 21, 2009 | Meade ETX90AT Maksutov Telescope with UHTC...
MotorFault
Hi
In response to your email the whole unit is being returned to supplier motor problem is manufacturers electrical fault the meade etx-125pe should have motor limiters fitted which stops the scope slewing more than two revolutions in any direction to stop potential wiring damage this unit does not have them or they are faulty hence motor fault.
Jan 18, 2009 | Meade ETX-125PE (500 x 127mm) Telescope
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Meade ETX-70 (240 x 70mm) Telescope Logo
264 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
