Question about Nintendo 64 Console
How to hook up nintendo 64?
I need to run t thru the VCR NOT using the red and white and yellow wires, i have a different conector thingie, it goes thru the cable HELP. Is there a diagram i can download????
  • atracy
    atracy Dec 28, 2007
    Thx so much!!! I just need to hook it up now :)
  • 3 Answers
Take the cable in the vcr out and put the nintendo piece in and at the back of the purple box on the nintendo cable cord should be an extra link where you fix the tv cable on.
Posted on Dec 28, 2007
I have trouble setting up my 50 inch T.V. It is connected to a VCR/DVD player recorder. I have a red, yellow, and white cable. Do I need anything more?
If possible use a AV SCART connection lead as you get audio & video! If you want to use the phono connection you need to connect all 3 red/white/yellow to the TV and the VCR/DVD! Red & white are audio, yellow video!
Dec 19, 2014 | Televison & Video
I need help getting a manual for my tv so i can hook my dvd vcr combo up My tv is a 37ld450 flat screen> If you dont have info on ownners manual can you help me hook up the red yellow white wire...
What is the name and model of your tv?
There are two ways to hook up a dvd/vcr to at tv.
1. Coaxil Cable - From VCR Cable Out To Tv - This goes to the tv cable jack. Tv should be on channel 3 or 4 to use it this way.
2. There are Yellow, Red, White Jacks on the vcr/dvd player. There should be a couple sets actually. One set should say OUTPUT on them. The colored jacks go from the vcr/dvd OUTPUT and goes to the same color jacks on the tv that say INPUT
TV must be on an A/V or Input channel for this to work
That is about all there is too it. If you need more info, just let me know. I am more than happy to help.
Mar 30, 2011 | Televison & Video
Using the red whit and yellow VCR cables, how do i
You must have a monaural (mono) TV even though it looks like you have speakers on each side. The VCR has stereo audio output red=right white=left yellow=video. Ideally you would buy a mixing tee to add the left and right signal. Or if your VCR supports it you can set it to mono output. Otherwise, just use the white (left) cable to feed the mono input (white) and of course the yellow to yellow for video. Just ignore the red wire or lightly tape over it to avoid any short. Best,
Apr 16, 2010 | Apex Digital AT2402 24" TV
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Connecting dtv box to vcr to dvd to the tv
you can hook the cable box into the vcr and then out of the vcr into the spliter which will turn your tv red/white/yellow signel input into two inputs( you can get this at most radio shacks for about $7.00 dollors) this leaves you with one more input for the dvd player
Please rate my response and come back if you need more help!
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
I can't hook up the vcr
I would strongly suggest connecting a plain, coaxial cable wire from your sat box to the the ANT IN of the VCR. then use another coaxial to run from the ANT OUT of the VCR to the TV. Then you can change your TV to channel 3 or 4 as appropriate.
If you have a newer digital satellite receiver, this setup may not work. In that case, use two sets of red/white/yellow cables - 1 set will run from the out of the satellite receiver to the audio, video IN of the VCR. The second set will run from the audio and video OUT of the VCR to your TV. Then change your television to Aux 1, aux2 or whatever channel that corresponds to the red/white yellow.
Have fun!
-Tha Mp3 Doctor
Dec 31, 2008 | Emerson EWV603 VHS VCR
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Cable conectors ?
yes just run your cable through a vcr. then to input such as a composite or component vid. or most cable boxes have composite out.. THE yellow cable. Then on your set switch to that input. ...
Dec 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nintendo 64 Console Logo
342 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
