Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Dishwasher Cycles will not stop running. They keep starting over. Help please!! Our 2 year old dishwasher will not stop running. It gets to the end of the cycle and starts over again. Plus, the cycles seem to have gotten longer. We called the Bosch repair number and they want $150 in cash to come out and look at it. Then they will come out and fix it!!!! Unbelievable!!!
    Problem Solver:
  • 14 Answers
Carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Posted on Jan 17, 2008
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
I have just moved into a resale home{two years old} and the bosch dishwasher has a terrible odor what do i do?
Works for me, empty the dishwasher of any dishes, silverware, pot or pans, get (2) jars of "Tang" orange drink. Use (1) jar to fill the soap dispenser and poor the rest into the bottom of the dishwasher.
Run the dishwasher through a normal wash cycle with no heat/dryer time.
Run a second time if necessary. The orange juice acid will dissolve the build up in the dishwasher and rinse it away. It also smells good when your done.
For regular maintenance, repeat once every 3 months or so. It will not harm the dishwasher and will keep the interior components fresh and clean.
Good luck.
Oct 23, 2009 | Bosch Dishwashers
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
One year old Bosch dishwasher stop wrking.will not
Start with the basics: Check the status of the breaker and the electrical connections under the toe kick panel. If the unitis getting power, You may want to call the dishwasher helpline to see if it is a recalled model. A free replacement of the control panel circuit board is available for many of these, but if the power switch is the culprit, you will need to buy a replacement button.
I have written a guide to help with drainage issues. The helpline number is near the top. It is here. Thanks!
Jul 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Burnt wiring on Bosch SHX46A06 Dishwasher
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
2,115 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
