Temporarily adjust the thermostat setting on the refrigerator and freezer. When the refrigerator starts running, open the freezer compartment door and listen for the fan in the freezer compartment to hear if it's running.
If it's not running, you can check with a volt meter by using one volt meter probe on the common side and one volt meter probe on the hot side of the fan motor. If the fan is getting voltage but is not turning, replace the evaporator fan.You may have to remove the back panel and the bottom panel inside the freezer compartment to access the evaporator fan.
Please use care when using the volt meter. If you are not familiar with electricity, you need to have someone who is skilled in the use of a volt meter to check it for you.
