Question about Motorola Mobility H700 Wireless Headset
Headsets keeps beeping and battery is not low
My headset recently started to make descending beeps everytime it's turned on the controls on the headset no longer work. I have to use the controls on my phone.
  • 1,003 Answers
Sounds like the non replaceable battery is bad get another headset cheap at
Posted on Jan 14, 2008
I can't pair my new bluetooth headset-genius (HS-905 BT) to my sony ericsson experia x10.
As of 2012: the button to hold is POWER.
1. make sure HS-905BT is off (hold Power till the blue light goes off, you hear descending sequence of tones)
2. hold Power to turn on (ascending tones, blue LED on) + KEEP holding Power till the blue LED flashes twice and you hear a double-beep. Device is ready for pairing.
Jun 02, 2012 | Radio Communications
My GN9330 headset keeps giving me repeated 3-beep descending sound sequence and will not allow me to talk. I need Help!!
I have three GN9330e all doing that. It's a pairing failure, and probably why Jabra discontinued the product. Jabra will tell you to work with your retailer/distributor if you're even within warranty. They wouldn't provide me any other help.
Aug 18, 2011 | GN Netcom GN 9330 Wireless Headset
Continuos (3) beep beep beep when voyager pro is turned on
Triple tones are usually associated with the battery having a very low charge. You should be getting approximately 5-6 hours of talk time and 5 days of stand by time from a single charge. If you are not, then the internal battery may be going out. The battery is hard wired and is not replaceable, however the headset does have a one year warranty from Plantronics and they will replace it within the warranty period.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Voyager PRO Bluetooth Headset
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
May 19, 2011 | Plantronics CS70 Wireless Headset
I am using my plantronic explorer 240 with my sony ecrisson vivaz mobile phone The sound is clear and people can hear me clearly too. However, my headset creates beep sound regularly when i am talking on...
If you are saying that it is the battery telling you that it is half when you start to hear the beeping, that may very well be the case. If it is the battery, you may need to keep it fully charged. The only other thing I know is that It will beep if you get too far away from the cell phone. Usually people put the cell phone on the same side as the headset. That way you are never out of range.
Mar 15, 2011 | Plantronics Explorer 240 Bluetooth Headset
At the beginning of use I get three beeping sounds. What can be done to fix this?
Mine was doing the same thing. I changed the batteries and it stopped beeping. I assume the beeps are a low battery warning.
Nov 30, 2010 | Plantronics Vista M22 Amplifier with...
One short beep during shutdown sequence
a short beep normally indicates that your phones network signal is low or absent, so you are aware that you are in a low signal area without looking at your phone, or two short peeps normally means the headset needs charging.
Sep 11, 2007 | Jabra BT250 Consumer Headset
Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
Jun 21, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
648 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
