Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher down my dishwasher does not seem to be filling up with water and the check water light keeps coming on
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Check supply to the d/w. it thats ok some have a shut of valve if water leaks into the btm panel or the inlet valve is faulty
Posted on Jan 03, 2008
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
No water entering dishwasher. seems to cycle but with now water.
open the dishwasher in the tub on your left bottom you will see a large plastic bubble lift the bubble (float) up and, down vertically, listen for a "click" the float sits above the water fill switch: the float's weight causes a pin on the float to press down on the switch to let water in the float sometimes can get stuck in the up position by debris and, prevent the fill switch from letting in water. When the float is lifted by the water in the tub to a predetermined height the pin comes off the fill switch lever and, turns off the water so that the dishwasher tub does not overflow. check this please.
May 18, 2010 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
No water comes in my kitchenAid dishwasher
you only need prime to pump water out if you are not getting water to D/W it is most likely the water control valve
Oct 23, 2009 | Dishwashers
Dishwasher won't fill with water
Hi, Make sure the wires didn't come off of the inlet valve. Make sure the waterlevel float located in the front corner, is able to move up and down. Make sure the water source valve wasn't shut off.
Just a few thing to look for to try and narrow this down
Vic
Jul 18, 2009 | Dishwashers
Water not draining from my bosch dishwasher
there will be something jamming up the drain pump empty the water out of the appliance if you study your operating instructions there will be an intsruction in it as to how to remove the drain pump cover and clear the impellor be carefull ill bet is a piece of glass
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Check water light comes on
is your appliance a miele? normally this is causeb by blockages ( bit of plastic or paper wrapping/ milk bottle tops etc) inside the impeller of the main circulating pump (motor) restricting the flow of water the only solution is to fisically remuve the obstraction by temporarelly remuving the motor and cleaning not a simple job
Jul 25, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher filling with water and flooding when not in use
check to see if your dishwasher is level. If it is unlevel the water could run to the front. Hope this helps.
Jun 04, 2008 | Dishwashers
Dishwasher not running
just got this, and have same prob, i have run through all checks
Aug 26, 2006 | Miele Premier-Plus Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
134 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
