Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
my clock with chimes is running about 2hrs a day slow.I did take the case off and reset the minue...
(More)
my clock with chimes is running about 2hrs a day slow.I did take the case off and reset the minue hand as it was off its loose and moving freely.
I was given a Strausebourg Manor Westminster Chime, Quartz wall clock. It measures approx 23x11....
(More)
I was given a Strausebourg Manor Westminster Chime, Quartz wall clock. It measures approx 23x11. Sounds beautiful, chimes on the hour. What is it worth. vernie dixon (vernie@coastalnow.net) Its in EX condition. thanks
westminster,battery,quartz movement,chimes exactly 4 min. after the hour. has a final adjustment...
(More)
westminster,battery,quartz movement,chimes exactly 4 min. after the hour. has a final adjustment screw on back. How do I set it to chime on the hour?
