Question about Dell Inspiron 9400 Notebook
Computer dead hallo, My Dell 9400 "get some water" , and it don't start , when I push the power button i heard some noise from HDD just like when triyng to start only for 5 seconds the power led is lit and after then it stops.All the oder parts don't start (display,video,coolers etc dead ) I think is some hardware components defect , try to remove one by one hardware parts but does happend nothing . Please help . Thanks in advance , sorry for my writting errors .
    Problem Solver:
  • 8 Answers
You need to let the system dry completely with no power or battery attached for a few days. If this doesn't work your laptop is pretty much gone from the water damage.
Posted on Dec 28, 2007
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
After start button is pushed several low buzzes is heard
Better check that power supply & where it plugs in at out. Also,make sure all the connections are plugged in tight inside. Never assume that a replaced part is good & if you went after-market for the power supply, don't go super cheap. Buy a good one with a good warranty & the same if not more juice than the original.
May 12, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell inspiron 9400- constant clicking noise like a mouse click locks computer
Probably a loose connection. Disassemble, check components, the reassemble.
Mar 12, 2010 | Dell Inspiron 9400 Notebook
When i start my Dell 9400 up and it takes 10 mins to load to windows XP, , when the windows loading screen comes up the FANS go crazy. I then wait till i'm at the desktop at which point i immediately shut...
Your battery HAS to stay in if its not working which means the OS needs the extra power.
If your fans are going crazy then your laptop is overheating!!!
Contact Dell
Dec 30, 2009 | Dell Inspiron 9400 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Dell inspririon 9400 wont start
(before you do anything remove the battery and th ac plug)remove the memory inside small door on the backside that has a "M" on it now once you remove the memory install the battery, power on if you hear a couple of beep tones you are half way there the motherboard is good so the problem is what you took out so there are two memory slot try them in the A slot one at a time.If the problem is memory replace it.
Good luck
Aug 29, 2009 | Dell Inspiron 9400 Notebook
Dell 9400 Won't Start
sounds like bad motherboard/power supply. Just to be sure though have you upgraded the ram? If you have more then one memory chip try siwtching out each one and seeing if it's boot farther. It's possible a dimm went bad or the port it's in went bad. Otherwise motherboard/powersupply
Dec 08, 2008 | Dell Inspiron 9400 Notebook
Fast overheating inspiron 9400
This sounds like the system has glitched. Do a system repair with your recovery or operating system disc. This should clear the glitch, get it back up and running, and cure the overheating problem. Try this and get back to me if there are any issues.
Aug 07, 2008 | Dell Inspiron 9400 Notebook
i suggest that you should replace the battery because batterey may be faulty take it down to your nearest pc repair shop
Jan 21, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
66 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
