Question about Mintek MDP-1770 Portable DVD Player
Mdp1720 portable dvd player
I have a mdp1720 and have not used it much. when a disc is put in it seems to stick on loading. please help
  • sissygaes Jan 21, 2008
    I have the exact same problem with my Mintek MDP1720 portable DVD player. Hardly used but it doesn't load. I paid $60 to have someone look at it and they said the part it needs is not available. The company went out of business.
Abbbbbbbnbnbnnbnbnbn
Posted on Jan 12, 2008
I have portable DVD model : LMD 5702RT When I put the DVD in and it starts loading, after about a minute it says no disc. And nothing is playing. Please help
try very gently cleaning optic (EYE) on player with a Qtip and rubbing alcohol
If that doesnt help; you need to replace the lens.
Jun 06, 2011 | TruTech LMD-5702RT Portable DVD Player
My logik lpd850 portable dvd player is turning on but doesnt seem to play any discs it just keeps reading no disc any solutions please.
the fault is obviously from the laser (lens) of your player. The lens is very weak such that it cannot load/read data on discs.
The best to do now is to replace the lens and your player will play all discs again.
Take care.
Jun 04, 2010 | US Logic DVD800P Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
WILL NOT PLAY A DISC
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Dvd plays cd's but not dvd's - gives no disc message
I have a durabrand portable dvd player we've owned for about 1yr and had just started messing up. When you put the dvd in it says it's loading and shows the blue dvd screen it just wont come on but you can hear it trying, please help what could be wrong?
Aug 12, 2008 | Durabrand DUR7 Portable DVD Player
Does not play
We have burned a movie to dvd+R from our computer. When we put the disk into the player we get a screen that says Video but we cannot seem to get it to play. Cannot find the manual to assist with it either. Could you please advise?? Thanks
Mar 24, 2007 | Insignia I-PD720 Portable DVD Player
Mintek MDP-1770 Portable DVD Player Logo
53 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
