Question about Mitsubishi WD-52525 52" Rear Projection HDTV
42" HDTV SEEING DOUBLE ON THE WORDING ON THE LEFT AND RIGHT SIDES OF THE SCREEN. FOLLOWED THE DIRECTIONS TO RESET THE CONVERGENCE, BUT NOTHING WORKED. THE PICTURE IS FINE, BUT THE WORDS STILL LOOK OFFSET(OVERLAPPED )
    Genius:
  • 1,153 Answers
Try self-diagnosis test and see what you come up with. See if any error. More info ctechnicians.com
Posted on Dec 29, 2007
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
Seeing double words and pictures more on the left side 52'
Ur convergence, 2 ICS is dead and a resister too.
U now a little about eclectonics,and soldering.
Go to the web.seach ur TV JCC AV-48WP3 48.Buy a convergence kid that related to ur tv name and model.Follow the directions.If go to shop about 300,do it ur self about a 100.
Aug 31, 2009 | JVC AV-48WP30 48" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Double images on half the tv
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 27, 2008 | Sony KP-43HT20 43" Rear Projection...
Blurryness
this sound to me is a convergence problem may cost to you 350$ if you want to do it by your self need to buy 2 stk 392 110 but if you dont know nothing about electronics i recomend you ta`ke the tv to a service center
Jul 27, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Double images red and blue lines on left and right side of screen
You need to replace both convergence ICs thy are STK392-040 you can get replacement ICs at the following Link and they will provide free instalation Instructions with pictures so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Jun 15, 2008 | Akai PTH5498 54" Rear Projection...
Akai pt5598hdix convergence problem.
go to the following link and click the contact link on the lower left side and tell them your model they will email you with the correct convergence ICs that you need for your model. they also provide free installation instructions with pictures and free tech support when you order the replacement ICs.
Apr 22, 2008 | Akai PT5598HD 55" Rear Projection...
Mitsu 47 inch tv's red light convergence is off!
The solution involves replacement of STK393-570 IC , which is
usually done by a skilled tech.........T.
May 22, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
