Question about Sony KP-53V80 53" Rear Projection Television
Sony 52" phantom picture, tech claims i need to get a repairman to adjust some motor
If it went out again then you probably need convergence chips, adjusting probably wont fix, call a tv repairman.
Posted on Sep 10, 2008
I have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
Posted on Mar 25, 2008
Sony Bravia 52 blurry Picture
Contact the authorized service center for Sony. So many adjustments have to be done after T'Con boar replacement. You can do it, if you are an expert engineer specialized in electronic engineering. If not, please do not make the set irreparable by doing more adjustments that you do not know. OK?
Aug 30, 2012 | Sony Kdl-52vl150 52" HDTV LCD TV
Sony KDL-52XBR9 has 4 horizontal lines approx 6 inches apart and blurring for first 5 - 10 minutes of use, then goes to normal picture. Picture looks to be divided into 5 sections horizontally
Sony has been having a problems with the LCD Pannel. This is right off the Sony website.
  • KDL52Z5100
  • KDL52XBR9
  • As part of our commitment to quality, under the terms of the limited warranty included with the product, Sony will replace or exchange the LCD Panel or television for any Affected Model experiencing picture anomalies due to LCD Panel failure through March 31, 2014. Please note that except as set forth in this announcement, the terms of the Sony limited warranty for these products continues to apply.
    In addition, customers who paid out-of-pocket to repair the LCD Panel due to picture anomalies on one of the Affected Models prior to the date of this announcement may be eligible to be reimbursed by mail for parts and labor expenses. To receive reimbursement, please follow all of the directions on the claim form for reimbursement; all claims must be postmarked by November 30, 2012. See claim form for complete terms and conditions.
    To arrange for repair of your television if experiencing these issues, please contact Sony at (888) 649-7669 begin_of_the_skype_highlighting (888) 649-7669 end_of_the_skype_highlighting
    Sep 21, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
    Aspect ratio - postion problem
    Unless you can control the aspect from your front panel controls, there are adjustments that can be made from the back. You might not be able to reach them yourself. If not you may have to call in a repairman to do it for you.
    Jul 11, 2009 | Televison & Video
    Picture is very yellow
    If this is an old 52 projection with bad color your oil in the tubes may need to be changed, focus & screen can be adjusted to improve picture. Changing oil is something a tech defintly has to do. Call a local tech & get pricing. Then u can weigh your options. Also tubes may be weak. If they need to be changed probably won't be worth it.
    Apr 23, 2009 | Samsung PCJ522R 52" Rear Projection...
    I have a sony rear projection 52 in tv i need help with...
    you can do it yourself if you can orer the part..its about 120.00 i think for the powerboard and then th time it takes you to put it in. if a repairman does it hes charging you at least 75.00 an hour for labor.
    Feb 09, 2009 | Sony KP-61S65 61" Rear Projection...
    Rca picture concave 52 in rear projection
    sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
    Oct 21, 2008 | RCA P52939 52" Rear Projection Television
    Sony Hi-Scan 1080i 52" projection TV colors won't converge
    No you will need to repace compents. Do you know how to solder and use a meter? If so I can assist you with the repair. If not you will need a repairman, he will cost you about $300-$500 for the fix.
    Tim Nolan
    Sep 13, 2008 | Sony KP-53HS20 TV
    Picture WAY messed up!!
    Go to menu, and under video or picture, go to advance setting and then go to convergence. This TV should be equipped with and automatic convergence adjustment. Just follow the instruction on you owners manual. If this does not fix it, it means that your convergence chips are shot, and you will need to have a train repairman fix it.
    Sep 09, 2008 | RCA D52W136D 52 in. TV/DVD Combo
    52'' sony old tv
    They are called CRTs ( picture Tubes) If you go to the following link and leave them a email with the model number of your sony they should have the correct CRT for your model, and they provide free tech support to help with instaltion instructions
    http://servicemanuals.vstore.ca/
    Jul 26, 2008 | Televison & Video
    Sony KP-53V80 53" Rear Projection Television Logo
    187 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
