Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Problem in fact my problem is that my fax machine panasonic kx-fp148 can't receive faxes. and there is a note at the display: cover open
  • tracy1212 Jan 22, 2008
    Printer Error code 055 and not in my manual
  • Anonymous Mar 31, 2014
    DISPLAY SAYS FAX MEMORY FULL AND CANT RECEIVE FAX
Try changing to a new toner. It helps for me. I just changed the whole toner, and the message got away.
Posted on Oct 03, 2008
    Scholar:
  • 159 Answers
The cover may not be prperly closed. Is it difficult to close? Sometimes the cartridge may not be inserted correctly so that the cover won't close properly.
Posted on Dec 29, 2007
What is the code 43 in a panasonic KX-FL511
Your error 43 refers to the fact that the fax you are calling does not answer. Talk to them and ask if their fax is set to "Auto Receive". its probably not.
Dec 01, 2016 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
How can I turn off the auto answer feature of the pansonic kx fh332. I never want it to pick up and go to fax mode.
Set the fax machine to Telephone mode by pressing
{RECEIVE MODE} until TEL MODE is
displayed.
You might also want to dowload the Operating Instructions for you fax machine: KX-FHD332 Operating Instructions (English) (17208 kb)
Aug 03, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Want to connect fax machine to pc
The KX-FM131BX, KX-FM131CX and KX-FM131AL do not connect directly to a computer. They only have RJ-11 connections (to the phone line (line in) for all models and to another phone or answering machine (in some cases).
To send and receive faxes with a computer, you need some sort of USB or network port on the machine. Brother has some that may fit your needs: http://www.brother-usa.com/Fax/ModelDetail/2/FAX2840/Overview is one of their lower end models.
I hope this helps.
Dec 06, 2017 | Panasonic KX-FM131 Fax
My fax machine is saying cover open when the cover is closed
unplug it and leave it unplugged for a minute then plug it back in and turn it on
Jan 06, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
How do I replace the ink in Panasonic Fax, KX FHD331
First of all make sure why cover is not closing .check its locks.for to change roll just see iside the machine i am sure there will bi a printed paper from manufactrer with picture how to change a roll .it will tell u the direction of roll.by following the picture just change it MIAN AKHLAQ
Dec 18, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic fax machine KX-FT73
in thermal fax call service 2 shows that there is problem in machine s mechanical .open back cover there is complete mechinacial at on side .just open cutter lock white lock then take it out from fx check mechanical properly .may bi some gear is broken in this there are also two sensors just clean them or replace.mian jee
Aug 08, 2008 | Office Equipment & Supplies
Faxes are incomplete or non-existent for Panasonic KX-FPC166
check the cover if it has been closed properly, if not check the cover lock and hinges.
Jul 16, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
70 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
