Question about Princeton Digital VL2018W Monitor
Monitor color is green.
I have dual monitors set up. I came in one morning and one of them is green. Every program I run is seen in green. When I transfer the program over to the other monitor it changes to a white background. How can I get rid of the green? I have already tried to reset to factory installation with no luck.
  • 2 more comments
  • Sue81 Dec 28, 2007
    The monitor is a Dell Model #E172FPt
  • mrfudd Jan 22, 2008
    my screen has a green tint after a few minutes it clears up and sometimes goes back to green tint
  • edoedo Mar 10, 2008
    color problems on 19" tft lcd monitor
  • pinklady5 Jul 04, 2008
    All around the edges my computor monitor has gone green, some parts look psychadelic in colour. How so I fix this? Dell monitor
    Problem Solver:
  • 4 Answers
I have an issue with my screen being green and it doesnt matter on what computer or vid card I use...or VGA or DVI inputs. This monitor also doesn't "blend" colors well. Is there a simple fix for this or is this a transistor problem?
Posted on Apr 26, 2008
Isolate whether the problem is with the monitor or the cable and video card. Try swapping the cables between the two monitors. If the other monitor now turns green then the issue is definitely with the cable and/or video card In this case try replacing the "green" cable. Sometimes a pin or two in the connector will get bent or lose connectivity with a change of temperature in the environment or the pets/children decide to yank on them. Make sure there are no breaks in the cable. Check both card socket and monitor socket for any blockages or shorts. If replacing the "green" cable doesn't help, then it's probably an issue with the video card itself in which case, you'll need a replacement.
Posted on Dec 28, 2007
I'm running dual Princton Monitors.This morning in booting up my computer one screen stayed completely blank with the message"For best picture quality change resolution to 1280x1024. This monitor...
possible that the video card has packed it in and is not responding for duel monitors
you could always try going to control panel , display section and check the settings of both monitors and the drivers for both monitors
to check the problem monitor change the setting from main display from the good unit to make the other monitor the main display
it should change over and the first monitor will then go bad
Apr 23, 2017 | Princeton Digital VL1514 Monitor
My dell inspiron 530 shows a block with red, white, green, and read, can't get to the my programs????
That "red white green and blue" block is a color pattern tester. that means the monitor is on, but is not receiving a signal, so its running tests. If your monitor has Digital input and VGA input, you may just need to switch inputs. Look for 1 or VGA if youre using the blue hook up. look for 2 or digital or dvi if youre using the larger white hook up. Some monitors also have 'auto detect'. If you are in "auto detect' bbut the color box is still there, then your monitor is not receiving video signal from the computer. It could indicate a bad cable or no signal being sent by the machine. If you try another monitor, you can see if the machine is working. I would try a monitor setting for VGA-1 first, since thats most common.
Jun 25, 2010 | Dell Inspiron 530 Desktop Computer
I have dual monitors. One now has different
Hi
check by connecting the VGA Cable of the faulty Monitor directly to the CPU means Tower connection ..
if the screen is still blue green then there is something wrong with the cable VGA Cable
Jan 22, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I usually dual monitor and have programs open on both. now that i am at home i do not have my second monitor only my laptop. when i go to open a certain program it opens on my "second monitor" that isnt...
You should go to the display properties on your laptop while at home and disable the dual monitor setting. You should then have all programs open on your laptop screen and not on the secondary monitor. If running XP, right click an open spot on desktop and select Properties. If running Vista, right click an open spot on desktop and select Personalize. Go to Display Settings, select the second monitor and uncheck "Extend the desktop onto this monitor". Hope this helps.
Apr 25, 2009 | Computers & Internet
Monitor won't turn off
Monitor will be like that until it is powered off. Only when it is powered off, the light goes off and there will be nothing on display.
Jan 20, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
A little too much green in the display
Nvidia control panel has adjustments for the color settings similar to the old color tv sets three controls. The controls come from your Nvidia control panel on your computer and not on the monitor itself. Chuck Housecall101@aol.com
Feb 10, 2008 | Balance CM2017 17" Monitor
Color management monitor profile change.
Good Morning aspevak
Depending on the internal video card, you have to install the correct driver for your monitor, and video card, other than that is just setting on control panel and advance setting , all the features, for the colors, or profiles.
Nov 27, 2007 | HP Media Center m7250n (ED842AA) PC...
Princeton Digital VL2018W Monitor Logo
304 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
