Question about Zanussi FJS1225W Front Load Washer
Not spinning machine will not spin
  • 1 more comment
  • Anonymous Mar 30, 2008
    While useing the dryer the heat still works but the unit stopped spinning.
  • sambos gal Apr 02, 2008
    washer is spinning but washing is still soaking wet
  • Anonymous Apr 12, 2008
    Not spinning not draining timer going through cycle ,but not spinning .
  • 1,294 Answers
First clean out your outlet filter. If this does not work, open up behind and tighten all points where wires are joined; due to vibrations these might have come loose. Plug off the wall first!!
Rate me if it works.....
Posted on Dec 28, 2007
  • prem mathew Apr 08, 2009
    Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
    For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTips for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ... for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repair for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
Jul 12, 2013 - Uploaded by
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
Nov 28, 2015 | Washing Machines
Flashing and beeping red spin light. won't spin
Have you emptied the filter recently. If it's clogged, the machine can't drain or spin.
Nov 15, 2013 | Washing Machines
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
Mar 26, 2011 | Washing Machines
Hswf 147 hoover washing machine wont spin
Not spinning at all can sometimes be caused by a blocked filter or drain pipe. Does your machine spin if you turn the dial to the spin only setting? Ours has developed a fault whereby it won't spin at the end of a normal cycle, but if I turn the dial to 'off' then to 'spin only', it will spin.
Dec 11, 2010 | Hoover Washing Machines
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Sep 16, 2010 | Kenmore Washing Machines
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
Zanussi FJS1225W Front Load Washer Logo
137 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
