Hi I found this info on the Nikon Australia website:
System Error" or "Lens
Error" message in LCD monitor
Question
My COOLPIX camera displays a "
Error" message. What should I do?
Answer
Having a "
Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing.
A
System Error is a general
error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
- Use the memory card that originally came with your camera (or a Nikon approved card).
- Remove and replace the battery.
On the other hand, a
Lens Error generally means that an
error has occured during the lens operation. To troubleshoot, please try the following:
- Turn off the camera.
- Turn on the camera.
If the above tips do not help, your camera
must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras.
We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible.
Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
thanks to 'aefornes' for the response to my battery door problem - actually the difficutly is not with the sourcing i do have a new replacement door - the problem is fitting it onto the fixed metal rod that hinges the door to the camera body
simple but i am baffled
thanks
Janes
